Installing cexp-2.2.3 for RTEMS 4.12
    Akiv Jhirad
    akivjh at gmail.com
    Mon Oct 23 15:32:50 UTC 2017
Great, thank you! I’ll install pc-rtems and report back with the success.
Best Regards,
Akiv Jhirad
From: Till Straumann [mailto:strauman at slac.stanford.edu]
Sent: October 22, 2017 9:42 PM
To: Akiv <akivjh at gmail.com>; users at rtems.org
Subject: Re: Installing cexp-2.2.3 for RTEMS 4.12
I have updated cexp so it should build for rtems-4.12.
git://github.com/till-s/cexpsh
Also supports ARM now.
- T.
On 10/05/2017 04:06 PM, Akiv wrote:
Hi All,
I have built RTEMS 4.12 for the pc686 BSP. I am now trying to install cexp 2.2.3. My goal is to run pc-rtems according to this guide: https://github.com/nasa/cFE/tree/master/psp/fsw/pc-rtems.
After configuring, when I run the make I get the following error.
bash-4.1$ ../cexp-CEXP_Release_2_2_3/configure --with-rtems-top=/home/rtems/pc_rtems/development/rtems/4.12 --host=i386-rtems4.12 --enable-std-rtems-installdirs
bash-4.1$ make -j 8
make  all-recursive
make[1]: Entering directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp'
Making all in pc686
make[2]: Entering directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686'
make  all-recursive
make[3]: Entering directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686'
Making all in regexp
make[4]: Entering directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/regexp'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/regexp'
Making all in libtecla
make[4]: Entering directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/libtecla'
i386-rtems4.12-gcc -B/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/ -specs bsp_specs -qrtems  -B /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/lib -mtune=pentiumpro -march=pentium  -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/include -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1 -I. -I../..//../cexp-CEXP_Release_2_2_3/libtecla   -I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1    -MT libtecla_a-getline.o -MD -MP -MF .deps/libtecla_a-getline.Tpo -c -o libtecla_a-getline.o `test -f 'getline.c' || echo '../..//../cexp-CEXP_Release_2_2_3/libtecla/'`getline.c
i386-rtems4.12-gcc -B/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/ -specs bsp_specs -qrtems  -B /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/lib -mtune=pentiumpro -march=pentium  -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/include -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1 -I. -I../..//../cexp-CEXP_Release_2_2_3/libtecla   -I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -D_POSIX_C_SOURCE=199506L -DPREFER_REENTRANT    -MT libtecla_r_a-getline.o -MD -MP -MF .deps/libtecla_r_a-getline.Tpo -c -o libtecla_r_a-getline.o `test -f 'getline.c' || echo '../..//../cexp-CEXP_Release_2_2_3/libtecla/'`getline.c
In file included from ../..//../cexp-CEXP_Release_2_2_3/libtecla/getline.c:154:0:
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:60:2: error: #error "This file is deprecated; remove this line if you absolutely have to use it"
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:62:8: error: redefinition of 'struct winsize'
 struct winsize {
In file included from /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:49:0,
                 from ../..//../cexp-CEXP_Release_2_2_3/libtecla/getline.c:59:
/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ttycom.h:52:8: note: originally defined here
 struct winsize {
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:74:0: warning: "IOCPARM_MASK" redefined
 #define IOCPARM_MASK 0x1fff  /* parameter length, at most 13 bits */
In file included from /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:45:0,
/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:47:0: note: this is the location of the previous definition
 #define IOCPARM_MASK ((1 << IOCPARM_SHIFT) - 1) /* parameter length mask */
../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:76:0: warning: "_IOC" redefined
 #define _IOC(inout,group,num,len) (inout | ((len & IOCPARM_MASK) << 16) | ((group) << 8) | (num))
/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:59:0: note: this is the location of the previous definition
 #define _IOC(inout,group,num,len)     \
 struct winsize {
 struct winsize {
make[4]: *** [libtecla_r_a-getline.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: *** [libtecla_a-getline.o] Error 1
make[4]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/libtecla'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp'
make: *** [all] Error 2
Would someone be able to provide some insight?
Best Regards,
Akiv Jhirad
users mailing list
users at rtems.org <mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20171023/772ec2b0/attachment-0002.html>
