Compiling Without Internet
Jacob Saina jsaina at terpmail.umd.edu
Tue Sep 5 19:47:22 UTC 2017
I think my problem was forgetting the --no-download flag. I accidentally
set my VM up with 1 core, so I will report back in about an hour...
On Tue, Sep 5, 2017 at 2:51 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Sep 5, 2017 at 1:41 PM, Jacob Saina <jsaina at terpmail.umd.edu>
> wrote:
>> Hi Chris,
>> I checked out "4.11" from the git repository, and did the following with
>> Internet:
>> ~/workspace/rsb/rtems$ ../source-builder/sb-set-builder --dry-run
>> --with-download --without-error-report --without-release-url
>> --prefix=/home/jsaina/rtems/4.11 4.11/rtems-arm
>> Then I disconnected my network cable and did:
>> This fails as follows:
>> reporting: tools/rtems-gdb-7.9-1.cfg -> arm-rtems4.11-gdb-7.9-x86_64-l
>> inux-gnu-1.xml
>> config: tools/rtems-tools-4.11-1.cfg
>> package: rtems-tools-4.11-1
>> git: reset: git://git.rtems.org/rtems-tools.git
>> git: fetch: git://git.rtems.org/rtems-tools.git ->
>> sources/git/rtems-tools.git
>> error: git command failed (/usr/bin/git): 128
>> Build FAILED
>>   See error report: rsb-report-rtems-tools-4.11-1.txt
>> Build Set: Time 1:10:37.113829
>> Build FAILED
>> What am I misunderstanding?
> Looks like things that are fetched from git have an issue with the
> predownload.
> Chris.. is there a way to check that the existing git checkout is in the
> right state
> before operating on it?
> If we still need to support cvs or svn, they might have the same issue.
> --joel
>> Thanks for your help,
>> Jacob
>> On Fri, Sep 1, 2017 at 6:49 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 2/9/17 3:38 am, Jacob Saina wrote:
>>> > I'm going to be building rsb, rtems, and applications with an
>>> intermittent
>>> > Internet connection, so I'd like to have all the pieces in place on
>>> disk
>>> > beforehand. How can I pull down all the necessary files and avoid
>>> failing
>>> > because of network access?
>>> To fetch the packages use:
>>> ../source-builder/sb-set-builder \
>>>            --dry-run --with-download \
>>>            --without-error-report \
>>>            --without-release-url \
>>>            4.12/rtems-arm
>>> Replace '4.12/rtems-arm' with the build set you want to build. This
>>> command
>>> comes from the release scripts [1].
>>> You should be able to move the 'source' and 'patch' contents to another
>>> location
>>> on you disk and then use the '--url' option with 'file://path'.
>>> Chris
>>> [1] https://git.rtems.org/rtems-release/tree/rtems-release-sources#n112
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170905/3525b395/attachment-0001.html>
