Compiling Without Internet
Jacob Saina
jsaina at terpmail.umd.edu
Tue Sep 5 21:21:29 UTC 2017
Seems to fail in the same place. Log attached.
On Tue, Sep 5, 2017 at 3:47 PM, Jacob Saina <jsaina at terpmail.umd.edu> wrote:
> I think my problem was forgetting the --no-download flag. I accidentally
> set my VM up with 1 core, so I will report back in about an hour...
> On Tue, Sep 5, 2017 at 2:51 PM, Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Sep 5, 2017 at 1:41 PM, Jacob Saina <jsaina at terpmail.umd.edu>
>> wrote:
>>> Hi Chris,
>>> I checked out "4.11" from the git repository, and did the following with
>>> Internet:
>>> ~/workspace/rsb/rtems$ ../source-builder/sb-set-builder --dry-run
>>> --with-download --without-error-report --without-release-url
>>> --prefix=/home/jsaina/rtems/4.11 4.11/rtems-arm
>>> Then I disconnected my network cable and did:
>>> This fails as follows:
>>> reporting: tools/rtems-gdb-7.9-1.cfg -> arm-rtems4.11-gdb-7.9-x86_64-l
>>> inux-gnu-1.xml
>>> config: tools/rtems-tools-4.11-1.cfg
>>> package: rtems-tools-4.11-1
>>> git: reset: git://git.rtems.org/rtems-tools.git
>>> git: fetch: git://git.rtems.org/rtems-tools.git ->
>>> sources/git/rtems-tools.git
>>> error: git command failed (/usr/bin/git): 128
>>> Build FAILED
>>> See error report: rsb-report-rtems-tools-4.11-1.txt
>>> Build Set: Time 1:10:37.113829
>>> Build FAILED
>>> What am I misunderstanding?
>> Looks like things that are fetched from git have an issue with the
>> predownload.
>> Chris.. is there a way to check that the existing git checkout is in the
>> right state
>> before operating on it?
>> If we still need to support cvs or svn, they might have the same issue.
>> --joel
>>> Thanks for your help,
>>> Jacob
>>> On Fri, Sep 1, 2017 at 6:49 PM, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 2/9/17 3:38 am, Jacob Saina wrote:
>>>> > I'm going to be building rsb, rtems, and applications with an
>>>> intermittent
>>>> > Internet connection, so I'd like to have all the pieces in place on
>>>> disk
>>>> > beforehand. How can I pull down all the necessary files and avoid
>>>> failing
>>>> > because of network access?
>>>> To fetch the packages use:
>>>> ../source-builder/sb-set-builder \
>>>> --dry-run --with-download \
>>>> --without-error-report \
>>>> --without-release-url \
>>>> 4.12/rtems-arm
>>>> Replace '4.12/rtems-arm' with the build set you want to build. This
>>>> command
>>>> comes from the release scripts [1].
>>>> You should be able to move the 'source' and 'patch' contents to another
>>>> location
>>>> on you disk and then use the '--url' option with 'file://path'.
>>>> Chris
>>>> [1] https://git.rtems.org/rtems-release/tree/rtems-release-sources#n112
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170905/368b601a/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: git command failed (/usr/bin/git): 128
Command Line: ../source-builder/sb-set-builder --prefix=/home/jsaina/rtems/4.11 --no-download 4.11/rtems-arm
Python: 2.7.12 (default, Nov 19 2016, 06:48:10) [GCC 5.4.0 20160609]
git://git.rtems.org/rtems-source-builder.git/origin/4a87913b1451b4f0d56864ce6824bb2b4747353c
Linux jsaina-VirtualBox 4.10.0-33-generic #37~16.04.1-Ubuntu SMP Fri Aug 11 14:07:24 UTC 2017 x86_64
Tail of the build log:
make[5]: Nothing to be done for 'install'.
make[5]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/testsuite'
make[5]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/data-directory'
make[6]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/data-directory'
/bin/bash ../../../gdb-7.9/gdb/data-directory/../../mkinstalldirs /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/syscalls
mkdir -p -- /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/syscalls
files='gdb-syscalls.dtd arm-linux.xml ppc-linux.xml ppc64-linux.xml i386-linux.xml amd64-linux.xml sparc-linux.xml sparc64-linux.xml mips-o32-linux.xml mips-n32-linux.xml mips-n64-linux.xml s390-linux.xml s390x-linux.xml' ; \
for file in $files; do \
f=../../../gdb-7.9/gdb/data-directory/../syscalls/$file ; \
if test -f $f ; then \
/usr/bin/install -c -m 644 $f /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/syscalls ; \
fi ; \
done
files='gdb/__init__.py gdb/frames.py gdb/FrameIterator.py gdb/FrameDecorator.py gdb/types.py gdb/printing.py gdb/prompt.py gdb/xmethod.py gdb/command/__init__.py gdb/command/xmethods.py gdb/command/frame_filters.py gdb/command/type_printers.py gdb/command/pretty_printers.py gdb/command/prompt.py gdb/command/explore.py gdb/function/__init__.py gdb/function/caller_is.py gdb/function/strfns.py gdb/printer/__init__.py gdb/printer/bound_registers.py' ; \
if test "x$files" != x ; then \
for file in $files ; do \
dir=`echo "$file" | sed 's,/[^/]*$,,'` ; \
/bin/bash ../../../gdb-7.9/gdb/data-directory/../../mkinstalldirs /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/python/$dir ; \
/usr/bin/install -c -m 644 ./python/$file /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/python/$dir ; \
done ; \
fi
mkdir -p -- /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/python/gdb/command
mkdir -p -- /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/python/gdb/function
mkdir -p -- /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/python/gdb/printer
files='' ; \
/bin/bash ../../../gdb-7.9/gdb/data-directory/../../mkinstalldirs /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/guile/$dir ; \
/usr/bin/install -c -m 644 ./guile/$file /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/guile/$dir ; \
done ; \
fi
/bin/bash ../../../gdb-7.9/gdb/data-directory/../../mkinstalldirs /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/system-gdbinit
mkdir -p -- /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/system-gdbinit
files='elinos.py wrs-linux.py' ; \
f=../../../gdb-7.9/gdb/data-directory/../system-gdbinit/$file ; \
/usr/bin/install -c -m 644 $f /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/gdb/system-gdbinit ; \
fi ; \
done
make[6]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/data-directory'
make[5]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/data-directory'
make[5]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[6]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[7]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make all-recursive
make[8]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[9]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[9]: Nothing to be done for 'all-am'.
make[9]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[8]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[7]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[6]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[7]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make install-recursive
make[10]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[11]: Entering directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
if test yes = no; then \
case 'linux-gnu' in \
darwin[56]*) \
need_charset_alias=true ;; \
darwin* | cygwin* | mingw* | pw32* | cegcc*) \
need_charset_alias=false ;; \
esac ; \
else \
need_charset_alias=false ; \
fi ; \
if $need_charset_alias; then \
/bin/bash ../../../../gdb-7.9/gdb/gnulib/../../mkinstalldirs /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib ; \
fi ; \
if test -f /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.alias; then \
sed -f ref-add.sed /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.alias > /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.tmp ; \
/usr/bin/install -c -m 644 /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.tmp /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.alias ; \
rm -f /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.tmp ; \
else \
sed -f ref-add.sed charset.alias > /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/lib/charset.tmp ; \
fi ; \
fi
make[11]: Nothing to be done for 'install-data-am'.
make[11]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
+ /bin/rm -rf /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/info/configure.info*
make[10]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib/import'
make[7]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[5]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb/build-gnulib'
make[4]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb'
make[3]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb'
make[2]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build/gdb'
make[1]: Nothing to be done for 'install-target'.
make[1]: Leaving directory '/home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build'
+ /bin/rm -f /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/info/dir
+ touch /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/info/dir
+ cd /home/jsaina/workspace/rsb/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
==> %clean:
+ echo ==> %clean:
copy: /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina => /home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm
reporting: tools/rtems-gdb-7.9-1.cfg -> arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt
making dir: /home/jsaina/workspace/rsb/rtems/build/tmp/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1-root-jsaina/home/jsaina/rtems/4.11/share/rtems/rsb
reporting: tools/rtems-gdb-7.9-1.cfg -> arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.xml
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/jsaina/rtems/4.11"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/jsaina/rtems/4.11" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/jsaina/workspace/rsb/rtems/sources"
script: 9: SB_BUILD_DIR="/home/jsaina/workspace/rsb/rtems/build/rtems-tools-4.11-1"
script: 10: # host == build, use build; host != build , host uses host and build uses build
script: 11: SB_HOST_CFLAGS="-O2 -pipe "
script: 12: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 13: SB_HOST_LDFLAGS="-L/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 14: SB_BUILD_CFLAGS="-O2 -pipe -I/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 15: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_LDFLAGS="-L/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 17: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 18: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 19: SB_ARCH="x86_64"
script: 20: SB_OS="linux"
script: 21: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 22: export SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 23: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 24: export SB_CFLAGS SB_CXXFLAGS
script: 25: # Documentation
script: 26: SB_DOC_DIR="/home/jsaina/rtems/4.11/share/doc"
script: 27: export SB_DOC_DIR
script: 28: # Packages
script: 29: SB_PACKAGE_NAME="rtems-tools-4.11-1"
script: 30: SB_PACKAGE_BUILDNAME="rtems-tools-4.11-1"
script: 31: SB_PACKAGE_VERSION="4.11"
script: 32: SB_PACKAGE_RELEASE="1"
script: 33: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 34: # Build directories
script: 35: export SB_PREFIX
script: 36: SB_BUILD_DIR="/home/jsaina/workspace/rsb/rtems/build/rtems-tools-4.11-1"
script: 37: SB_BUILD_ROOT="/home/jsaina/workspace/rsb/rtems/build/tmp/rtems-tools-4.11-1-root-jsaina"
script: 38: SB_BUILD_ROOT_BINDIR="/home/jsaina/workspace/rsb/rtems/build/tmp/rtems-tools-4.11-1-root-jsaina/${SB_PREFIX_CLEAN}/bin"
script: 39: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 40: SB_BUILD_CXC_DIR="/home/jsaina/workspace/rsb/rtems/build/rtems-tools-4.11-1-cxc"
script: 41: SB_BUILD_CXC_ROOT="/home/jsaina/workspace/rsb/rtems/build/tmp/rtems-tools-4.11-1-jsaina-cxc"
script: 42: SB_BUILD_CXC_ROOT_BINDIR="/home/jsaina/workspace/rsb/rtems/build/tmp/rtems-tools-4.11-1-jsaina-cxc/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 44: SB_TMPROOT="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm"
script: 45: SB_TMPPREFIX="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}"
script: 46: SB_TMPBINDIR="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 48: SB_TMPCXCROOT="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina/4.11/rtems-arm"
script: 49: SB_TMPCXCPREFIX="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina-cxc/4.11/rtems-arm/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPCXCBINDIR="/home/jsaina/workspace/rsb/rtems/build/tmp/sb-jsaina-cxc/4.11/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 52: # Extra path support
script: 53: SB_EXTRAPATH="/home/jsaina/workspace/rsb/source-builder"
script: 54: # The compiler flags
script: 55:
script: 56:
script: 57: export CFLAGS_FOR_TARGET
script: 58: export CXXFLAGS_FOR_TARGET
script: 59: # Set up the path. Put the CXC path first.
script: 60: if test -n "${SB_TMPBINDIR}" ; then
script: 61: PATH="${SB_TMPBINDIR}:$PATH"
script: 62: fi
script: 63: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 64: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 65: fi
script: 66: if test -n "${SB_EXTRAPATH}" ; then
script: 67: PATH="${SB_EXTRAPATH}:$PATH"
script: 68: fi
script: 69:
script: 70:
script: 71: export PATH
script: 72: # Default environment set up.
script: 73: LANG=C
script: 74: export LANG
script: 75: unset DISPLAY || :
script: 76: umask 022
script: 77: cd "/home/jsaina/workspace/rsb/rtems/build/rtems-tools-4.11-1"
script: 78: echo "=> rtems-tools-4.11-1:"
script: 79: echo "==> %prep:"
script: 80: build_top=$(pwd)
script: 81: rtems_tools_source="rtems-tools-4.11"
script: 82: source_dir_rtems_tools=${rtems_tools_source}
source setup: rtems-tools-4.11-1: source rtems-tools -q -n ${rtems_tools_source}
making dir: /home/jsaina/workspace/rsb/rtems/sources/git
git: fetch: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
