What are the files that correspond to the Device Tree in the RTEMS-libBSD?
mfg
mfg at ugr.es
Mon Sep 18 11:36:12 UTC 2017
Hello all,
I have a question related to the email previously sent by Moritz.
Actually I'm working with a board similar to zc702 board.
My question is:
If we have a device tree, it is easy to see which is the register is
being used, for example in Zedboard's DT:
phy at 0 {
compatible = "marvell,88e1510";
device_type = "ethernet-phy";
reg = <0x0>;
marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
linux,phandle = <0x4>;
phandle = <0x4>;
The PHY register for MDIO is the 0x0.
In RTEMS, Which file I have to touch for change this? I mean if I want
to use the 0x2 instead 0x0 or, for example, if I wanted to add another
ethernet interface.
I've only worked with DT and I'm not sure how to change it in
RTEMS-libBSD.
Thanks in advance.
Marco Fuentes García.
