pthread_getattr_np does not work
xuelin.tian at qkmtech.com
Fri Sep 22 08:43:37 UTC 2017
>> But, this test just checks the return value, not the value of elements
>> in pthread_attr_t structure. When I tried to print out these values,
>> the same result as before appeared, all 0...
> It would be good to check the expected values with test assertions.
The return value of pthread_getattr_np is correct, I double checked it. But the values of element in attr structure are not correct, like stack_addr and stack_size.
>> So, how can I modify the source code in rtems to let this function
>> work? Thanks a lot.
> You have to edit:
> cpukit/posix/src/pthreadgetattrnp.c
Yes, I know this. I just do not know how to do this. The implementation of pthread_getattr_np of 4.11 and 4.12 are different, I just do not know where do I start from...
Best wishes,
Date: 2017-09-22 16:33
To: xuelin.tian at qkmtech.com; users at rtems.org
Subject: Re: pthread_getattr_np does not work
On 22/09/17 10:24, xuelin.tian at qkmtech.com wrote:
> I found out that there is a test in 4.12-master about
> pthread_getattr_np, so I compiled that one and ran it.
> The result shows that this function works well, like this
> *** BEGIN OF TEST PSXGETATTRNP 1 ***
> Init - pthread_getattr_np - attr NULL - EINVAL
> Init - pthread_getattr_np - invalid id - ESRCH
> Init - pthread_attr_init
> Init - pthread_attr_setinheritsched - PTHREAD_EXPLICIT_SCHED
> Init - pthread_attr_setschedpolicy to SCHED_RR
> Init - pthread_attr_setschedparam to minimum priority + 2
> Init - pthread_attr_getstack
> Init - pthread_attr_setstack double the stacksize
> Init - pthread_attr_getguardsize
> Init - pthread_attr_setguardsize double the guardsizecreate
> Init - Lower pri
> Init - raise priority to max
> Init - pthread_ority
> Thread - pthread_getattr_np - Verify value
> Thread - pthread_setschedparam: Setting highest priority SCHED_FIFO
> Thread - Detach
> Thread - Verify SCHED_FIFO policy
> Thread - Verify max priority
> Thread - Verify detached
> *** END OF
> work? Thanks a lot.
You have to edit:
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20170922/993b33d3/attachment-0001.html>
