pthread_getattr_np does not work
Fri Sep 22 08:48:02 UTC 2017
On 22/09/17 10:43, xuelin.tian at qkmtech.com wrote:
> >> So, how can I modify the source code in rtems to let this function
> >> work? Thanks a lot.
> > You have to edit:
> > cpukit/posix/src/pthreadgetattrnp.c
> Yes, I know this. I just do not know how to do this. The
> implementation of pthread_getattr_np of 4.11 and 4.12 are different, I
> just do not know where do I start from...
It should be fixed on the master first, then you can back port a fix.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
