pthread_getattr_np does not work
xuelin.tian at qkmtech.com
Fri Sep 22 08:55:34 UTC 2017
OK, I will try to do some fix on this function. And if Sherrill and you have time, please take some time on this. Thanks a lot.
Best wishes,
Date: 2017-09-22 16:48
To: xuelin.tian at qkmtech.com; users at rtems.org
Subject: Re: pthread_getattr_np does not work
On 22/09/17 10:43, xuelin.tian at qkmtech.com wrote:
> >> So, how can I modify the source code in rtems to let this function
> >> work? Thanks a lot.
> > You have to edit:
> > cpukit/posix/src/pthreadgetattrnp.c
> Yes, I know this. I just do not know how to do this. The
> implementation of pthread_getattr_np of 4.11 and 4.12 are different, I
> just do not know where do I start from...
It should be fixed on the master first, then you can back port a fix.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20170922/d651dfe1/attachment.html>
