Timers in a task context
Wed Apr 11 06:19:36 UTC 2018
On 10/04/18 14:20, Matthew J Fletcher wrote:
> Hi
> It would be good to know if rtems_task_self() is expected to return
> the 'TIME' a.k.a rtems_timer_initiate_server() task id, when a timer
> created with rtems_timer_server_fire_after() fires.
The use of rtems_task_self() in timer routines is a bad application
behaviour from my point of view. The execution context of the timer
routines is an implementation detail.
> If it is then i will have to make up some work around, as quite a bit
> of code thats coming over from ThreadX depends on, it returning the
> previous 'user' task, not the previous 'system' task.
You can easily fix this with some glue code, e.g.
typedef struct your_timer {
   rtems_id task_which_created_this_timer;
   rtems_id timer;
   void *arg;
   void (*handler)(struct your_timer *, void *);
} your_timer;
void create_timer(your_timer *t)
   t->task_which_created_this_timer = rtems_task_self();
   rtems_timer_create(..., &t->timer);
void timer_wrapper(rtems_id timer, void *arg)
   your_timer *t = arg;
   (*t->handler)(t, t->arg);
void fire_timer(your_timer *t, ...)
   rtems_timer_fire_after(..., timer_wrapper, t);
rtems_id get_task_which_created_this_timer(const your_timer *t)
    return t->task_which_created_this_timer;
> Personally it does feel wrong that the behavior of rtems_task_self()
> changes behavior depending if you use the timer server or not.
rtems_task_self() returns the id of the executing thread.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
