GSOC'18 project description
Russell Haley russ.haley at gmail.com
Mon Apr 30 22:38:03 UTC 2018
On Mon, Apr 30, 2018 at 3:05 AM, Sebastian Huber <
> Hello Vidushi,
> On 30/04/18 09:15, Vidushi Vashishth wrote:
>> Hello!
>> I am Vidushi Vashishth, and I have been selected for the Google Summer of
>> Code'18 program. I look forward to a productive and enriching summer with
>> the RTEMS community.
> I am looking forward to get some new insights into a network stack
> performance issue with 10Gbit/s Ethernet on a QorIQ T4240 with your tracing
> support.
>> I will be working on enhancement of the tracing system of RTEMS, under
>> the guidance of mentors: Gedare Bloom, Chris Johns and Sebastian Huber. The
>> main objectives of my project are threefold:
>> 1) Combine the Common Trace Format with the functionality of the Trace
>> Linker. I will be working with barectf and rtems-tld in this regard.
>> 2) Coming up with a synchronisation and transport mechanism to send trace
>> records to the host machine.
>> 3) Investigate the importance of live tracing functionality and addition
>> of kernel level tracing. I will design both possibilities and decide which
>> one to work on by the end of phase 1 of my evaluation.
> I work currently on a new low level infrastructure to support gathering of
> thread (create, delete, terminate, switch) and interrupt (entry, exit)
> events. Similar to the capture engine, but with less overhead. I would like
> to be able to gather at least 200000 events per second per processor (24 on
> the QorIQ T4240). This results in about 80MiB/s of data so that I can
> transfer it easily via a 1Gbit/s Ethernet interface.
> I don't know how to setup the CTF infrastructure to display this data. I
> hope that you can help me here.
>> The wiki page for my project is: https://devel.rtems.org/wiki/G
>> SoC/2018/EnhancementRuntimeTracing
>> I will be documenting the progress of my project on my blog:
>> https://vidushivashishth.github.io/
>> Both of these sources are empty right now but will be modified with
>> relevant information over the course of this summer.
> I would prefer to use the ticket system as much as possible for this
> project.
Should Udit also be using the ticket system? Or is the ticket system deemed
less important for his project?
> The main audience for the runtime tracing are the RTEMS users. A key issue
> is to provide adequate documentation so that it is easy to use. If you need
> this tracing then you probably have a nasty application issue and no time
> to struggle with setting up things with a project deadline looming. Where
> should this documentation go? A new chapter in the User Manual
> https://docs.rtems.org/branches/master/user/index.html
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180430/2f4de290/attachment-0002.html>
