GSOC'18 project description
Mon Apr 30 22:41:12 UTC 2018
On Mon, Apr 30, 2018 at 5:38 PM, Russell Haley <russ.haley at gmail.com> wrote:
> On Mon, Apr 30, 2018 at 3:05 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Vidushi,
>> On 30/04/18 09:15, Vidushi Vashishth wrote:
>>> Hello!
>>> I am Vidushi Vashishth, and I have been selected for the Google Summer
>>> of Code'18 program. I look forward to a productive and enriching summer
>>> with the RTEMS community.
>> I am looking forward to get some new insights into a network stack
>> performance issue with 10Gbit/s Ethernet on a QorIQ T4240 with your tracing
>> support.
>>> I will be working on enhancement of the tracing system of RTEMS, under
>>> the guidance of mentors: Gedare Bloom, Chris Johns and Sebastian Huber. The
>>> main objectives of my project are threefold:
>>> 1) Combine the Common Trace Format with the functionality of the Trace
>>> Linker. I will be working with barectf and rtems-tld in this regard.
>>> 2) Coming up with a synchronisation and transport mechanism to send
>>> trace records to the host machine.
>>> 3) Investigate the importance of live tracing functionality and addition
>>> of kernel level tracing. I will design both possibilities and decide which
>>> one to work on by the end of phase 1 of my evaluation.
>> I work currently on a new low level infrastructure to support gathering
>> of thread (create, delete, terminate, switch) and interrupt (entry, exit)
>> events. Similar to the capture engine, but with less overhead. I would like
>> to be able to gather at least 200000 events per second per processor (24 on
>> the QorIQ T4240). This results in about 80MiB/s of data so that I can
>> transfer it easily via a 1Gbit/s Ethernet interface.
>> I don't know how to setup the CTF infrastructure to display this data. I
>> hope that you can help me here.
>>> The wiki page for my project is: https://devel.rtems.org/wiki/G
>>> SoC/2018/EnhancementRuntimeTracing
>>> I will be documenting the progress of my project on my blog:
>>> https://vidushivashishth.github.io/
>>> Both of these sources are empty right now but will be modified with
>>> relevant information over the course of this summer.
>> I would prefer to use the ticket system as much as possible for this
>> project.
> Should Udit also be using the ticket system? Or is the ticket system
> deemed less important for his project?
As much as possible, all students should. I know for the POSIX improvements
project, I set it up as a "meta project" where adding a method or set of
methods is a single ticket.
There is a tag for "SoC" projects.
>> The main audience for the runtime tracing are the RTEMS users. A key
>> issue is to provide adequate documentation so that it is easy to use. If
>> you need this tracing then you probably have a nasty application issue and
>> no time to struggle with setting up things with a project deadline looming.
>> Where should this documentation go? A new chapter in the User Manual
>> https://docs.rtems.org/branches/master/user/index.html
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180430/a0f3a3b3/attachment-0002.html>
