SMP related question
Sat Aug 11 22:41:00 UTC 2018
On 10/08/2018 22:30, Sebastian Huber wrote:
> Hello Stavros,
> you can do this with a custom clustered scheduler configuration:
> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#clustered-scheduler-configuration
I had a brief look over the documentation you provided but could not see how to
achieve the result you are saying.
> Alternatively, on a recent version the default SMP scheduler supports a one-to-one affinity.  You can set it in a device driver.
Is there an example of how to do this?
> ----- Am 10. Aug 2018 um 14:10 schrieb Passas, Stavros stavros.passas at intel.com:
>> Hi,
>> In my local SMP enabled RTEMS, I notice core1 starting the Init() function of
>> the user application.
>> Is there a way to enforce RTEMS to run the Init() in the boot processor, when
>> SMP is enabled?
>> Best Regards,
>>   Stavros
>> Intel Research and Development Ireland Limited
>> Registered in Ireland
>> Registered Office: Collinstown Industrial Park, Leixlip, County Kildare
>> Registered Number: 308263
>> This e-mail and any attachments may contain confidential material for the sole
>> use of the intended recipient(s). Any review or distribution by others is
>> strictly prohibited. If you are not the intended recipient, please contact the
>> sender and delete all copies.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
