SMP related question
Mon Aug 20 06:23:07 UTC 2018
On 12/08/18 00:41, Chris Johns wrote:
> On 10/08/2018 22:30, Sebastian Huber wrote:
>> Hello Stavros,
>> you can do this with a custom clustered scheduler configuration:
>> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#clustered-scheduler-configuration
> I had a brief look over the documentation you provided but could not see how to
> achieve the result you are saying.
Stavros, asked for two things.
1. A way to change properties of the initialization task which are not covered by configuration options
https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#classic-api-initialization-tasks-table-configuration
before the initialization task runs. To do this some user provided code must execute after the initialization task is created and before it runs. My suggestion to use a device driver initialization function for this doesn't work. The initialization task is created after the device driver initialization. It can be done via a system initialization handler using the undocumented RTEMS_SYSINIT_ITEM(). Maybe also a high priority constructor, however, in this case the task already runs.
2. A way to pin a task to a particular processor. There are two options to do this in RTEMS. One is a clustered scheduler configuration, the other is the use of a thread to processor affinity.
>> Alternatively, on a recent version the default SMP scheduler supports a one-to-one affinity.  You can set it in a device driver.
> Is there an example of how to do this?
> Chris
>> ----- Am 10. Aug 2018 um 14:10 schrieb Passas, Stavros stavros.passas at intel.com:
>>> Hi,
>>> In my local SMP enabled RTEMS, I notice core1 starting the Init() function of
>>> the user application.
>>> Is there a way to enforce RTEMS to run the Init() in the boot processor, when
>>> SMP is enabled?
>>> Best Regards,
>>>    Stavros
>>> Intel Research and Development Ireland Limited
>>> Registered in Ireland
>>> Registered Office: Collinstown Industrial Park, Leixlip, County Kildare
>>> Registered Number: 308263
>>> This e-mail and any attachments may contain confidential material for the sole
>>> use of the intended recipient(s). Any review or distribution by others is
>>> strictly prohibited. If you are not the intended recipient, please contact the
>>> sender and delete all copies.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
