rtems-libbsd fails for gr740
Nicolas Tsiogkas
lou.nick at gmail.com
Fri Aug 24 09:32:33 UTC 2018
Hi Sebastian,
I'm getting this error from repositories cloned yesterday (rtems commit:
a36aa8628f11385ab0d9061d6b37d179879322e7, libbsd commit:
1d99262f59e5b7427e926ed045610a1c049be337)
Ok that would explain that it is that different.
Thanks,
Niko
On Fri, Aug 24, 2018 at 11:23 AM Sebastian Huber <
> Hello Nicolas,
> On 24/08/18 10:59, Nicolas Tsiogkas wrote:
> > Hi,
> > I am trying to build the libbsd for a gr740 target. It fails while
> > building debugger01.exe with error:
> > Waf: Entering directory
> `/home/niko/rtems/rtems-src/rtems-libbsd/build/sparc-rtems5-gr740-default'
> > [1906/2014] Linking build/sparc-rtems5-gr740-default/debugger01.exe
> /home/niko/rtems/5/lib/gcc/sparc-rtems5/7.3.0/../../../../sparc-rtems5/bin/ld:
> > cannot find -ldebugger
> > collect2: error: ld returned 1 exit status
> > Waf: Leaving directory
> > Build failed
> > -> task in 'debugger01.exe' failed with exit status 1 (run with -v to
> > display more information)
> > as far as I understand debugger was moved out of libbsd but it is not
> > built for the gr740 for some reason. Is this a known normal behaviour?
> do you have this error with the latest master versions of RTEMS and libbsd?
> > In addition which networking stack version is used in the rtems kernel
> > (when I build with --enable-networking)? Is it from FreeBSD9.3 or even
> > older? as the bpf provided there is not on par with the rtems-libbsd one.
> The network stack included in the RTEMS sources is about 20 years old.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20180824/a06b7816/attachment-0001.html>
