examples-v2 build issue with qemuprep
Matthew Gann
mgann at prc-hsv.com
Fri Aug 24 18:11:58 UTC 2018
I had assumed that because the QorIQ P1020RDB didn't explicitly appear on
the rtems-bsps in 5 as it did in 4.11 that support had not yet been ported
to 5. Is it somehow a part of QorIQ_E500 now?
I have RTEMS 5 built for qemuprep, and the examples do build, but I've run
into a different problem. I had qemu-system-ppc set up to load the .ralf
files generated in samples. It does not seem to like the .exe files
examples-v2 generates (an ELF format I think?). Is there a way to convert,
or to get qemu-system-ppc to load an ELF?
On Fri, Aug 24, 2018 at 12:33 AM Sebastian Huber <
> On 23/08/18 22:46, Matthew Gann wrote:
> > I'm focused on the 4.11 branch, as the 5 didn't seem to support the
> > QorIQ 1020rdb board yet, which I plan on moving to when hardware is in
> > hand. Until then, Qemuprep seemed the best emulation route...
> The QorIQ P1020RDB is supported by RTEMS 5 (and 4.11). I would
> definitely use RTEMS 5 on this board (I have it on my office and could
> test it).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Matthew Gann
Senior Engineer - Paragon Research Corporation
This message is intended for the addressee only and may contain Paragon
Research Corporation (PRC) confidential or privileged information. Use or
distribution of such confidential information is strictly prohibited
without the prior written permission of PRC. If you have received this
message in error, please contact the sender immediately and delete the
message and attachments from your computer.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180824/a50521d1/attachment-0001.html>
