Simulation RTEMS5 qemuprep
Matthew Gann mgann at prc-hsv.com
Tue Aug 28 15:10:37 UTC 2018
I ran through the build on RTEMS5 for qemuprep, including the sample
tests.  I was also able to build the "examples-v2" code for qemuprep.  I'm
running into issues trying to launch the emulator, though.
On RTEMS 4.11 I'd been able to run the all the samples on the emulator with
the following command:
qemu-system-ppc -M prep -cpu 604 -bios ${RTEMS_PATH:?Need to source
enable-rtems.sh}/bsp/powerpc-rtems4.11/qemuprep/lib/qemu_fakerom.bin
-append "--console=/dev/com1" -monitor stdio -vga none -kernel
"${SAMPLEDIR}/hello/hello.ralf"
On RTEMS 5 I can no longer find the *.ralf files.  I've tried running
qemu-system-ppc against the ELF files (*.exe) and I've tried using
powerpc-rtems5-objcopy to convert them to *.ralf files and run them, with
no success (*powerpc-rtems-objcopy -O binary -R .comment -S hello/hello.exe
hello.ralf*).  I've tried running the emulator with the same options as
RTEMS4 (and every variation I can think of) and I get serial0 console as my
only output, which I suspect is qemu displaying something.  I've tried
-nographic as well, which just gives no output.
Can someone provide a bit of guidance on getting qemuprep running in qemu
on RTEMS5?
Thanks in advance
Matthew Gann
Senior Engineer - Paragon Research Corporation
This message is intended for the addressee only and may contain Paragon
Research Corporation (PRC) confidential or privileged information.  Use or
distribution of such confidential information is strictly prohibited
without the prior written permission of PRC.  If you have received this
message in error, please contact the sender immediately and delete the
message and attachments from your computer.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180828/54a808a2/attachment.html>
