How to configure _Sysinit handler list?
Mon Aug 20 06:01:14 UTC 2018
On 20/08/18 05:12, Chris Johns wrote:
> On 17/08/2018 02:21, Aaron Bufkin wrote:
>> Never mind.  I figured it out.  The RTEMS_SYSINIT_ITEM() macro allows me to
>> insert initialization handlers to the loop that I mentioned earlier.
> Thank you for let us know. If you think the documentation in ...
> https://docs.rtems.org/branches/master/c-user/initialization.html
> .. could be improved we would welcome a patch.
The question is, if this stuff is part of the API. The RTEMS_* name
suggests it, however, I am not sure if we should make this a documented
interface.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
