examples-v2 build issue with qemuprep
Thu Aug 23 20:31:47 UTC 2018
On Thu, Aug 23, 2018 at 10:34 AM, Matthew Gann <mgann at prc-hsv.com> wrote:
> I've built the qemuprep tools and bsp, and successfully simulated the
> samples (hello.ralf, etc).  I was attempting to move on to the examples-v2
> project so I could get a better feel for how to build a standalone RTEMS
> project.  I have not been able to make it build correctly, and from the
> messages it seems like there may be an issue with the build.  If I follow
> the directions in the README files I get the following:
> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ git clone -b 4.11
> git://git.rtems.org/examples-v2.git
> Cloning into 'examples-v2'...
> remote: Counting objects: 1661, done.
> remote: Compressing objects: 100% (877/877), done.
> remote: Total 1661 (delta 1019), reused 1257 (delta 758)
> Receiving objects: 100% (1661/1661), 543.00 KiB | 211.00 KiB/s, done.
> Resolving deltas: 100% (1019/1019), done.
> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ cd examples-v2/
> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ git
> submodule init
> Submodule 'rtems_waf' (git://git.rtems.org/chrisj/rtems_waf.git)
> registered for path 'rtems_waf'
> submodule update
> Cloning into '/opt/development/projects/booster/rtems-qemuprep/
> examples-v2/rtems_waf'...
> Submodule path 'rtems_waf': checked out '7bcf72b72ec42f2feedac5f5cc5f2f
> 57d50b5d2b'
> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ waf
> configure --rtems=${RTEMS_PATH}/bsp --rtems-tools=${RTEMS_PATH}/tools
> --rtems-bsps=powerpc/qemuprep
> Setting top to                           : /opt/development/projects/
> Setting out to                           : /opt/development/projects/
> booster/rtems-qemuprep/examples-v2/build
> Architectures                            : powerpc-rtems4.11
> Board Support Package                    : powerpc-rtems4.11-qemuprep
> Checking for program 'powerpc-rtems4.11-gcc' : /opt/development/projects/
> booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc
> Checking for program 'powerpc-rtems4.11-g++' : /opt/development/projects/
> booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-g++
> Checking for program 'powerpc-rtems4.11-ld'  : /opt/development/projects/
> booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ld
> Checking for program 'powerpc-rtems4.11-ar'  : /opt/development/projects/
> booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ar
> Checking for program 'powerpc-rtems4.11-nm'  : /opt/development/projects/
> booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-nm
> Checking for program 'powerpc-rtems4.11-objdump' :
> /opt/development/projects/booster/rtems-qemuprep/tools/
> bin/powerpc-rtems4.11-objdump
> Checking for program 'powerpc-rtems4.11-objcopy' :
> bin/powerpc-rtems4.11-objcopy
> Checking for program 'powerpc-rtems4.11-readelf' :
> bin/powerpc-rtems4.11-readelf
> Checking for program 'powerpc-rtems4.11-strip'   :
> bin/powerpc-rtems4.11-strip
> Checking for program 'rtems-ld'                  :
> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-ld
> Checking for program 'rtems-tld'                 :
> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-tld
> Checking for program 'rtems-bin2c'               :
> /opt/development/projects/booster/rtems-qemuprep/bsp/bin/rtems-bin2c
> Checking for program 'tar'                       : /bin/tar
> Checking for program 'gcc, cc'                   :
> Checking for program 'ar'                        :
> Checking if the -o link must be split from arguments : no
> Checking for program 'g++, c++'                      :
> Checking for program 'gas, gcc'                      :
> Checking for RTEMS headers                           : started
> -> processing test results                           : all ok
> Checking for RTEMS_DEBUG                             : no
> Checking for RTEMS_MULTIPROCESSING                   : no
> Checking for RTEMS_NEWLIB                            : yes
> Checking for RTEMS_POSIX_API                         : yes
> Checking for RTEMS_SMP                               : no
> Checking for RTEMS_NETWORKING                        : yes
> Checking for RTEMS_ATOMIC                            : no
> 'configure' finished successfully (3.420s)
> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ waf -v
> Waf: Entering directory `/opt/development/projects/booster/rtems-qemuprep/
> examples-v2/build/powerpc-rtems4.11-qemuprep'
> [  1/116] Creating build/powerpc-rtems4.11-qemuprep/filesystem/fat_
> ramdisk/FilesystemImage
> 10:24:16 runner ' tar -C /opt/development/projects/booster/rtems-qemuprep/
> examples-v2/filesystem/fat_ramdisk/rootfs -cf filesystem/fat_ramdisk/FilesystemImage
> [  2/116] Creating build/powerpc-rtems4.11-qemuprep/file_io/crc/
> FilesystemImage
> 10:24:16 runner ' tar -C /opt/development/projects/booster/rtems-qemuprep/examples-v2/file_io/crc/rootfs
> -cf file_io/crc/FilesystemImage . '
> [  3/116] Processing build/powerpc-rtems4.11-qemuprep/filesystem/fat_
> 10:24:16 runner ' /opt/development/projects/booster/rtems-qemuprep/bsp/bin/rtems-bin2c
> filesystem/fat_ramdisk/FilesystemImage /opt/development/projects/
> booster/rtems-qemuprep/examples-v2/build/powerpc-
> rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.c && touch
> examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.h
> [  4/116] Processing build/powerpc-rtems4.11-qemuprep/filesystem/fat_
> [  5/116] Processing build/powerpc-rtems4.11-qemuprep/file_io/crc/
> FilesystemImage
> file_io/crc/FilesystemImage /opt/development/projects/
> rtems4.11-qemuprep/file_io/crc/FilesystemImage.c && touch
> examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.h
> [  6/116] Compiling build/powerpc-rtems4.11-qemuprep/file_io/crc/
> FilesystemImage.c
> 10:24:16 runner ['/opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc',
> '-qrtems', '-B/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/lib/',
> powerpc-rtems4.11/qemuprep/lib/', '--specs', 'bsp_specs',
> '-mcpu=powerpc', '-mcpu=powerpc', '-mmultiple', '-mmultiple', '-mstring',
> '-mstring', '-mstrict-align', '-mstrict-align', '-O2', '-g', '-qrtems',
> '-Ifile_io/crc', '-I../../file_io/crc', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1',
> '-DHAVE_RTEMS_H=1', '-DPACKAGE_VERSION="1.0.0"',
> 'file_io/crc/FilesystemImage.c', '-c', '-o/opt/development/projects/
> rtems4.11-qemuprep/file_io/crc/FilesystemImage.c.2.o']
> [  7/116] Compiling hello/hello_world_c/test.c
> '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
> '../../hello/hello_world_c/test.c', '-c', '-o/opt/development/projects/
> booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/
> hello_world_c/test.c.1.o']
> [  8/116] Compiling hello/posix_hello_world/test.c
> '../../hello/posix_hello_world/test.c', '-c',
> '-o/opt/development/projects/booster/rtems-qemuprep/
> posix_hello_world/test.c.1.o']
> [  9/116] Compiling hello/both_hello/test.c
> powerpc-rtems4.11-gcc: fatal error: /opt/development/projects/
> booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/bsp_specs:
> attempt to rename spec 'endfile' to already defined spec 'old_endfile'
> compilation terminated.
I tried this on the master and qemuprep built the examples OK.
I am unsure how well the waf for examples-v2 worked on 4.11 but for some
reason the -qrtems flag is in the wrong place and -B is twice. It should be:
-B PREFIX/TARGET/BSP/lib/ -specs bsp_specs -qrtems
and those arguments should be in that exact order and no part of them
should appear twice.
In this case, the -qrtems is too early and having no impact which I think
explains the issues.
What's the installed file powerpc-rtems5-qemuprep.pc contain?
> In file included from /opt/development/projects/
> lib/include/libcpu/powerpc-utility.h:40:0,
> lib/include/bsp/vectors.h:40,
> lib/include/bsp.h:17,
>                  from ../../hello/posix_hello_world/test.c:20:
> powerpc-rtems4.11/qemuprep/lib/include/rtems/powerpc/powerpc.h:283:2:
> error: #error "Unsupported CPU Model"
>                  from ../../hello/hello_world_c/test.c:21:
> * Node /opt/development/projects/booster/rtems-qemuprep/
> is created more than once (full message on 'waf -v -v'). The task
> generators are:
>   1. 'fat_ramdisk.exe' in /opt/development/projects/
> booster/rtems-qemuprep/examples-v2/filesystem/fat_ramdisk
>   2. 'fat_ramdisk.texe' in /opt/development/projects/
> If you think that this is an error, set no_errcheck_out on the task
> instance
> examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.c
> generators are:
> instance
> Waf: Leaving directory `/opt/development/projects/booster/rtems-qemuprep/
> Build failed
>  -> task in 'crc.exe' failed with exit status 1:
> {task 140287200672176: c FilesystemImage.c -> FilesystemImage.c.2.o}
>  -> task in 'posix_hello.exe' failed with exit status 1:
> {task 140287209486528: c test.c -> test.c.1.o}
>  -> task in 'hello.exe' failed with exit status 1:
> {task 140287209485568: c test.c -> test.c.1.o}
> If I change the following line in the wscript to add -Dmpc604 "bld.env.CFLAGS
> += ['-O2','-g','-Dmpc604']" I get this error:
> clean
> 'clean-powerpc-rtems4.11-qemuprep' finished successfully (0.017s)
> 'configure' finished successfully (0.614s)
> 10:30:49 runner ' tar -C /opt/development/projects/booster/rtems-qemuprep/
> FilesystemImage
> 10:30:49 runner ' tar -C /opt/development/projects/booster/rtems-qemuprep/examples-v2/file_io/crc/rootfs
> 10:30:49 runner ' /opt/development/projects/booster/rtems-qemuprep/bsp/bin/rtems-bin2c
> FilesystemImage
> [  6/116] Compiling hello/hello_world_c/test.c
> 10:30:49 runner ['/opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc',
> '-mstring', '-mstrict-align', '-mstrict-align', '-O2', '-g', '-Dmpc604',
> [  7/116] Compiling hello/posix_hello_world/test.c
> [  8/116] Compiling hello/both_hello/test.c
> '../../hello/both_hello/test.c', '-c', '-o/opt/development/projects/
> rtems4.11-qemuprep/hello/both_hello/test.c.1.o']
> rtems4.11-qemuprep/hello/both_hello/test.c.2.o']
> [ 10/116] Compiling hello/both_hello/test.c
> rtems4.11-qemuprep/hello/both_hello/test.c.3.o']
> [ 11/116] Compiling gdb/overwrite/overwrite.c
> '../../gdb/overwrite/overwrite.c', '-c', '-o/opt/development/projects/
> booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/gdb/
> overwrite/overwrite.c.1.o']
> [ 12/116] Compiling gdb/overwrite/rtems_init.c
> '../../gdb/overwrite/rtems_init.c', '-c', '-o/opt/development/projects/
> overwrite/rtems_init.c.1.o']
> [ 13/116] Compiling filesystem/fat_ramdisk/init.c
> '-Ifilesystem/fat_ramdisk', '-I../../filesystem/fat_ramdisk',
> '-DPACKAGE_VERSION="1.0.0"', '../../filesystem/fat_ramdisk/init.c', '-c',
> fat_ramdisk/init.c.2.o']
> generators are:
> instance
> generators are:
> instance
> Build failed
>  -> task in 'fat_ramdisk.exe' failed with exit status 1:
> {task 140363104493032: c init.c -> init.c.2.o}
> Is there something I'm doing wrong, or is there a simple fix for this?
> Thanks in advance
> Matthew Gann
> Senior Engineer - Paragon Research Corporation
> This message is intended for the addressee only and may contain Paragon
> Research Corporation (PRC) confidential or privileged information.  Use or
> distribution of such confidential information is strictly prohibited
> without the prior written permission of PRC.  If you have received this
> message in error, please contact the sender immediately and delete the
> message and attachments from your computer.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180823/58cda032/attachment-0002.html>
