examples-v2 build issue with qemuprep
Matthew Gann mgann at prc-hsv.com
Thu Aug 23 20:46:22 UTC 2018
I'm focused on the 4.11 branch, as the 5 didn't seem to support the QorIQ
1020rdb board yet, which I plan on moving to when hardware is in hand.
Until then, Qemuprep seemed the best emulation route...
# pkg-config support file for RTEMS BSP qemuprep
# Warning: This stuff is experimental and may be changed at any time.
prefix=/opt/development/projects/booster/rtems-qemuprep/bsp
exec_prefix=/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11
libdir=${exec_prefix}/qemuprep/lib
includedir=${exec_prefix}/qemuprep/lib/include
CFLAGS=-mcpu=powerpc -mmultiple -mstring -mstrict-align -D__ppc_generic -O2
-g -Wall -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs
RTEMS_BSP=qemuprep
Version: 4.11.1.99
Description: RTEMS BSP qemuprep
Libs:
Cflags: -qrtems -B${exec_prefix}/lib/ -B${libdir}/ --specs bsp_specs
${CFLAGS}
On Thu, Aug 23, 2018 at 3:31 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Aug 23, 2018 at 10:34 AM, Matthew Gann <mgann at prc-hsv.com> wrote:
>> I've built the qemuprep tools and bsp, and successfully simulated the
>> samples (hello.ralf, etc).  I was attempting to move on to the examples-v2
>> project so I could get a better feel for how to build a standalone RTEMS
>> project.  I have not been able to make it build correctly, and from the
>> messages it seems like there may be an issue with the build.  If I follow
>> the directions in the README files I get the following:
>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ git clone -b 4.11
>> git://git.rtems.org/examples-v2.git
>> Cloning into 'examples-v2'...
>> remote: Counting objects: 1661, done.
>> remote: Compressing objects: 100% (877/877), done.
>> remote: Total 1661 (delta 1019), reused 1257 (delta 758)
>> Receiving objects: 100% (1661/1661), 543.00 KiB | 211.00 KiB/s, done.
>> Resolving deltas: 100% (1019/1019), done.
>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep$ cd examples-v2/
>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ git
>> submodule init
>> Submodule 'rtems_waf' (git://git.rtems.org/chrisj/rtems_waf.git)
>> registered for path 'rtems_waf'
>> submodule update
>> Cloning into
>> '/opt/development/projects/booster/rtems-qemuprep/examples-v2/rtems_waf'...
>> Submodule path 'rtems_waf': checked out
>> '7bcf72b72ec42f2feedac5f5cc5f2f57d50b5d2b'
>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ waf
>> configure --rtems=${RTEMS_PATH}/bsp --rtems-tools=${RTEMS_PATH}/tools
>> --rtems-bsps=powerpc/qemuprep
>> Setting top to                           :
>> Setting out to                           :
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build
>> Architectures                            : powerpc-rtems4.11
>> Board Support Package                    : powerpc-rtems4.11-qemuprep
>> Checking for program 'powerpc-rtems4.11-gcc' :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc
>> Checking for program 'powerpc-rtems4.11-g++' :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-g++
>> Checking for program 'powerpc-rtems4.11-ld'  :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ld
>> Checking for program 'powerpc-rtems4.11-ar'  :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-ar
>> Checking for program 'powerpc-rtems4.11-nm'  :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-nm
>> Checking for program 'powerpc-rtems4.11-objdump' :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-objdump
>> Checking for program 'powerpc-rtems4.11-objcopy' :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-objcopy
>> Checking for program 'powerpc-rtems4.11-readelf' :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-readelf
>> Checking for program 'powerpc-rtems4.11-strip'   :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-strip
>> Checking for program 'rtems-ld'                  :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-ld
>> Checking for program 'rtems-tld'                 :
>> /opt/development/projects/booster/rtems-qemuprep/tools/bin/rtems-tld
>> Checking for program 'rtems-bin2c'               :
>> /opt/development/projects/booster/rtems-qemuprep/bsp/bin/rtems-bin2c
>> Checking for program 'tar'                       : /bin/tar
>> Checking for program 'gcc, cc'                   :
>> Checking for program 'ar'                        :
>> Checking if the -o link must be split from arguments : no
>> Checking for program 'g++, c++'                      :
>> Checking for program 'gas, gcc'                      :
>> Checking for RTEMS headers                           : started
>> -> processing test results                           : all ok
>> Checking for RTEMS_DEBUG                             : no
>> Checking for RTEMS_MULTIPROCESSING                   : no
>> Checking for RTEMS_NEWLIB                            : yes
>> Checking for RTEMS_POSIX_API                         : yes
>> Checking for RTEMS_SMP                               : no
>> Checking for RTEMS_NETWORKING                        : yes
>> Checking for RTEMS_ATOMIC                            : no
>> 'configure' finished successfully (3.420s)
>> mgann at obsidian:~/dev/projects/booster/rtems-qemuprep/examples-v2$ waf -v
>> Waf: Entering directory
>> `/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep'
>> [  1/116] Creating
>> build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage
>> 10:24:16 runner ' tar -C
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/filesystem/fat_ramdisk/rootfs
>> -cf filesystem/fat_ramdisk/FilesystemImage . '
>> [  2/116] Creating
>> build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/file_io/crc/rootfs
>> -cf file_io/crc/FilesystemImage . '
>> [  3/116] Processing
>> 10:24:16 runner '
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.c
>> && touch
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/FilesystemImage.h
>> [  4/116] Processing
>> 10:24:16 runner '
>> && touch
>> [  5/116] Processing
>> 10:24:16 runner '
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.c
>> && touch
>> /opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.h
>> [  6/116] Compiling
>> 10:24:16 runner
>> ['/opt/development/projects/booster/rtems-qemuprep/tools/bin/powerpc-rtems4.11-gcc',
>> '-qrtems',
>> '-B/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/lib/',
>> '-B/opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/',
>> '--specs', 'bsp_specs', '-mcpu=powerpc', '-mcpu=powerpc', '-mmultiple',
>> '-mmultiple', '-mstring', '-mstring', '-mstrict-align', '-mstrict-align',
>> '-O2', '-g', '-qrtems',
>> '-O2', '-g', '-Ifile_io/crc', '-I../../file_io/crc',
>> '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
>> '-DPACKAGE_VERSION="1.0.0"', 'file_io/crc/FilesystemImage.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/file_io/crc/FilesystemImage.c.2.o']
>> [  7/116] Compiling hello/hello_world_c/test.c
>> 10:24:16 runner
>> '-qrtems',
>> '-O2', '-g', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
>> '../../hello/hello_world_c/test.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/hello_world_c/test.c.1.o']
>> [  8/116] Compiling hello/posix_hello_world/test.c
>> 10:24:16 runner
>> '-qrtems',
>> '../../hello/posix_hello_world/test.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/posix_hello_world/test.c.1.o']
>> [  9/116] Compiling hello/both_hello/test.c
>> powerpc-rtems4.11-gcc: fatal error:
>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/bsp_specs:
>> attempt to rename spec 'endfile' to already defined spec 'old_endfile'
>> compilation terminated.
> I tried this on the master and qemuprep built the examples OK.
> I am unsure how well the waf for examples-v2 worked on 4.11 but for some
> reason the -qrtems flag is in the wrong place and -B is twice. It should be:
> -B PREFIX/TARGET/BSP/lib/ -specs bsp_specs -qrtems
> and those arguments should be in that exact order and no part of them
> should appear twice.
> In this case, the -qrtems is too early and having no impact which I think
> explains the issues.
> What's the installed file powerpc-rtems5-qemuprep.pc contain?
>> In file included from
>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/libcpu/powerpc-utility.h:40:0,
>>                  from
>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/bsp/vectors.h:40,
>>                  from
>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/bsp.h:17,
>>                  from ../../hello/posix_hello_world/test.c:20:
>> /opt/development/projects/booster/rtems-qemuprep/bsp/powerpc-rtems4.11/qemuprep/lib/include/rtems/powerpc/powerpc.h:283:2:
>> error: #error "Unsupported CPU Model"
>>                  from
>>                  from
>>                  from ../../hello/hello_world_c/test.c:21:
>> * Node
>> is created more than once (full message on 'waf -v -v'). The task
>> generators are:
>>   1. 'fat_ramdisk.exe' in
>>   2. 'fat_ramdisk.texe' in
>> If you think that this is an error, set no_errcheck_out on the task
>> instance
>> * Node
>> generators are:
>> instance
>> Waf: Leaving directory
>> Build failed
>>  -> task in 'crc.exe' failed with exit status 1:
>> {task 140287200672176: c FilesystemImage.c -> FilesystemImage.c.2.o}
>> '-qrtems',
>>  -> task in 'posix_hello.exe' failed with exit status 1:
>> {task 140287209486528: c test.c -> test.c.1.o}
>> '-qrtems',
>>  -> task in 'hello.exe' failed with exit status 1:
>> {task 140287209485568: c test.c -> test.c.1.o}
>> '-qrtems',
>> If I change the following line in the wscript to add -Dmpc604 "bld.env.CFLAGS
>> += ['-O2','-g','-Dmpc604']" I get this error:
>> clean
>> 'clean-powerpc-rtems4.11-qemuprep' finished successfully (0.017s)
>> Setting top to                           :
>> Setting out to                           :
>> 'configure' finished successfully (0.614s)
>> [  1/116] Creating
>> 10:30:49 runner ' tar -C
>> [  2/116] Creating
>> [  3/116] Processing
>> 10:30:49 runner '
>> && touch
>> [  4/116] Processing
>> 10:30:49 runner '
>> && touch
>> [  5/116] Processing
>> 10:30:49 runner '
>> && touch
>> [  6/116] Compiling hello/hello_world_c/test.c
>> 10:30:49 runner
>> '-qrtems',
>> '-O2', '-g', '-Dmpc604', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1',
>> '-DHAVE_RTEMS_H=1', '../../hello/hello_world_c/test.c', '-c',
>> [  7/116] Compiling hello/posix_hello_world/test.c
>> 10:30:49 runner
>> '-qrtems',
>> '-DHAVE_RTEMS_H=1', '../../hello/posix_hello_world/test.c', '-c',
>> [  8/116] Compiling hello/both_hello/test.c
>> 10:30:49 runner
>> '-qrtems',
>> '-DHAVE_RTEMS_H=1', '../../hello/both_hello/test.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.1.o']
>> 10:30:49 runner
>> '-qrtems',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.2.o']
>> [ 10/116] Compiling hello/both_hello/test.c
>> 10:30:49 runner
>> '-qrtems',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/hello/both_hello/test.c.3.o']
>> [ 11/116] Compiling gdb/overwrite/overwrite.c
>> 10:30:49 runner
>> '-qrtems',
>> '-DHAVE_RTEMS_H=1', '../../gdb/overwrite/overwrite.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/gdb/overwrite/overwrite.c.1.o']
>> [ 12/116] Compiling gdb/overwrite/rtems_init.c
>> 10:30:49 runner
>> '-qrtems',
>> '-DHAVE_RTEMS_H=1', '../../gdb/overwrite/rtems_init.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/gdb/overwrite/rtems_init.c.1.o']
>> [ 13/116] Compiling filesystem/fat_ramdisk/init.c
>> 10:30:49 runner
>> '-qrtems',
>> '-O2', '-g', '-Dmpc604', '-qrtems',
>> '-O2', '-g', '-Dmpc604', '-Ifilesystem/fat_ramdisk',
>> '-I../../filesystem/fat_ramdisk', '-DHAVE_RTEMS_SCORE_CPUOPTS_H=1',
>> '-DHAVE_RTEMS_H=1', '-DPACKAGE_VERSION="1.0.0"',
>> '../../filesystem/fat_ramdisk/init.c', '-c',
>> '-o/opt/development/projects/booster/rtems-qemuprep/examples-v2/build/powerpc-rtems4.11-qemuprep/filesystem/fat_ramdisk/init.c.2.o']
>> * Node
>> generators are:
>> instance
>> * Node
>> generators are:
>> instance
>> Build failed
>>  -> task in 'fat_ramdisk.exe' failed with exit status 1:
>> {task 140363104493032: c init.c -> init.c.2.o}
>> '-qrtems',
>> Is there something I'm doing wrong, or is there a simple fix for this?
>> Thanks in advance
>> Matthew Gann
>> Senior Engineer - Paragon Research Corporation
>> This message is intended for the addressee only and may contain Paragon
>> Research Corporation (PRC) confidential or privileged information.  Use or
>> distribution of such confidential information is strictly prohibited
>> without the prior written permission of PRC.  If you have received this
>> message in error, please contact the sender immediately and delete the
>> message and attachments from your computer.
>> users mailing list
>> users at rtems.org
Matthew Gann
URL: <http://lists.rtems.org/pipermail/users/attachments/20180823/5b6bd2b6/attachment-0002.html>
