examples-v2 build issue with qemuprep
Fri Aug 24 00:22:34 UTC 2018
On Thu, Aug 23, 2018, 6:53 PM Chris Johns <chrisj at rtems.org> wrote:
> On 24/08/2018 08:33, Matthew Gann wrote:
> > I've modified the c/src/bsp.pc.in <http://bsp.pc.in> file and still see
> the same
> > issues (still need the -Dmpc604, and it still fails on fat_ramdisk).  It
> looks
> > like the -qrtems argument did move in the argument list, but didn't fix
> this
> > particular issue.  See the output below.
> > I've also tried disabling the build of the fat_ramdisk (and others
> following it)
> > and it still broke.  Is there a better starting place than the
> examples-v2 for 4.11?
> I suggest updating rtems_waf to the latest and see how it goes on 4.11.
> Hmmm, that will not work, it looks like the rtems_waf module has not been
> updated to point to the new repo location. That will need a ticket. I did
> not do
> the move and so I am not sure what git magic is needed.
Mentioning the -Dmpc604 reminds me that I worked recently to remove the
need for any bsp.to use a -Dxxx. This was fragile since user code had to
use exactly the same flags.
Chris is rtems_waf stripping those out? It was only maybe a dozen bsps that
used it.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20180823/f051de1b/attachment-0002.html>
