Qualification of RTEMS SMP (ECSS)
Tue Dec 4 13:19:33 UTC 2018
Hello,
I would like to announce to the RTEMS community a 24 month project
sponsored by the European Space Agency (ESA).
The main goal of the project is to enable European space missions to use
RTEMS as a software product in criticality category C (this is basically
category B without independent software verification and validation,
ISVV). Criticality category C means:
http://ecss.nl/standard/ecss-q-st-80c-rev-1-software-product-assurance-15-february-2017/
"Software that if not executed, or if not correctly executed, or whose
anomalous behaviour can cause or contribute to a system failure
resulting in: Major consequences"
In ECSS-Q-ST-40C  major consequences are characterized in Table 6-1 as a
major mission degradation without effects to the outside world of the
system. A future activity may perform ISVV to enable a use in category B
settings.
The qualification will be done according to ECSS standards
(ECSS-E-ST-40C and ECSS-Q-ST-80C). The standards are available at
http://ecss.nl/
free of charge after registration.
The project consists of four tasks.
1. Qualification toolchain
This task aims to produce a tool chain so that qualification related
work can be carried out efficiently. For example: document generation,
test suite runs (including code coverage), test reporting, test result
archiving, code metrics, static code analysis, traceability (e.g.
requirements to tests), etc.
2. RTEMS SMP qualification data package
This task covers the main RTEMS components (source code, tests,
documentation; new: requirements document, ECSS standard tailoring) so
that a data package for space mission consumers can be generated.
3. RTEMS SMP formal verification
This is a research project. The aim is to apply formal methods for the
verification of a subset of the RTEMS SMP algorithms.
4. RTEMS SMP application porting
The goal of this task is to port an existing uniprocessor space software
from RTEMS 4.8 (RTEMS Improvement by Edisoft) to RTEMS SMP. The
algorithms used by the software needs to be parallelized.
The project partners are:
* Edisoft (prime)
* Lero (https://www.lero.ie/) with Lero researchers from Trinity College
Dublin and University of Limerick
* Jena-Optronik GmbH and embedded brains GmbH
The results of this activity should be open source and available to the
RTEMS community. The actual planning needs to be discussed at
devel at rtems.org in the next couple of weeks. One of the first topics is
the definition of a space profile which defines the feature set subject
to this project.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
