Cache routines working with a processor set?
Daniel Hellstrom daniel at gaisler.com
Fri Dec 21 14:15:15 UTC 2018
On 2018-12-21 15:06, Sebastian Huber wrote:
> Hello Daniel,
> On 21/12/2018 14:55, Daniel Hellstrom wrote:
>> I missed to respond to this email.. It is not currently used by our
>> drivers currently, I think the original use case here is when
>> L3/L2/L1-cache is not updated after DMA. For example, the GR740 can
>> be configured to make DMA directly to SDRAM memory, "behind" the
>> L2-cache. In this mode the system is not coherent. To avoid the L2
>> cache containing incorrect data, one approach is to use a "DMA
>> address region" and configure a L2-cache MTR regions. However, the
>> L1-cache would still not be updated since it L1 D-cache is not
>> snooping the memory bus but only the CPU bus which the DMA master is
>> not writing to in this configuration. Using the MMU and marking pages
>> non-cacheable could resolve this to a cost. Another approach would be
>> to flush those lines or the whole D-cache instead of using the MMU.
>> At that time, it was under consideration to add line/page flushing to
>> the GR740 L1-cache.
> this sounds like a very specialized use case. I don't think we should
> provide an architecture-independent API for this. If you really need
> this for a highly optimized driver on the GR740, you can use a special
> purpose function.
Makes sense. There may be other ideas behind this them that I can't
recall. It fine with me to remove them.
>> For the I-cache we need to flush when modifying instructions, like
>> the trap vector. But this patch seems to only involve d-cache.
> The instruction cache software broadcast is still supported.
good.
