RTEMS POSIX Priority Inversion Issue.
"구철회"
chkoo at kari.re.kr
Fri Dec 28 07:04:59 UTC 2018
What is the relation between main thread and pthread1/2/3?
If the main thread has a control to wake up each pthread1/2/3, it gonna be in trouble when the prioirty of the main thread is lower than pthread1/2/3s because the main thread has never chance to run it, which is required to other threads.
However why do you assign so much long integer value to priority?
Cheol
--------- 원본 메일 ---------
보낸사람 : "JunBeom Kim (EmbedCoreTech)" <jbkim at e-coretech.kr>
받는사람 : <users at rtems.org>
받은날짜 : 2018-12-28 (금) 15:45:48
제목 : RTEMS POSIX Priority Inversion Issue.
Dear Sir, I am testing RTEMS POSIX thread priority. I am still using RTEMS 4.12 in 2017 year. There are four pthreads(main, pthread1, pthread2, pthread3) on two cores in my test case. - main pthread is running on core 1. - pthread1, pthread2, pthread3 is running on core 2. - All threads are doing GPIO toggling action in while(1) loop. - my configuration for timeslice quantum is 25ms. As I know from RTEMS POSIX manual, there is below statement. In the RTEMS implementation of the POSIX API, the priorities range from the low priority of sched_get_priority_min() to the highest priority of sched_get_priority_max(). Numerically higher values represent higher priorities. But, when I test this, lower value is doing as higher priority. Higher value is doing as lower priority. Is this correct operation ? Case 0) All threads are same priority. [/] # pthread ID NAME CPU SHED PRI STATE MODES EVENTS WAITINFO ------------------------------------------------------------------------------ 0b010001 main_thread 1 MEDF 2147483645 READY P:T:nA NONE 0b010002 pthread1 2 MEDF 2147483645 READY P:T:nA NONE 0b010003 pthread2 2 MEDF 2147483645 READY P:T:nA NONE 0b010004 pthread3 2 MEDF 2147483645 READY P:T:nA NONE Case 1) pthread3 is lower priority according to manual. But, pthread3 is higher priority in my case. [/] # pthread ID NAME CPU SHED PRI STATE MODES EVENTS WAITINFO ------------------------------------------------------------------------------ 0b010001 main_thread 1 MEDF 2147483645 READY P:T:nA NONE 0b010002 pthread1 2 MEDF 2147483646 READY P:T:nA NONE 0b010003 pthread2 2 MEDF 2147483646 READY P:T:nA NONE 0b010004 pthread3 2 MEDF 1789569706 READY P:T:nA NONE Case 2) pthread3 is higher priority according to manual. pthread1 and pthread2 are higher priority than pthread3. [/] # pthread ID NAME CPU SHED PRI STATE MODES EVENTS WAITINFO ------------------------------------------------------------------------------ 0b010001 main_thread 1 MEDF 2147483645 READY P:T:nA NONE 0b010002 pthread1 2 MEDF 1789569706 READY P:T:nA NONE 0b010003 pthread2 2 MEDF 1789569706 READY P:T:nA NONE 0b010004 pthread3 2 MEDF 2147483646 READY P:T:nA NONE Please advise. Best Regards, JunBeom Kim ~~~~~~~~~~~~~~~~~~~~~~ President / EmbedCoreTech Phone: +82-31-396-5584 Fax: +82-504-065-5720 Mobile:+82-10-6425-5720 Email: jbkim at e-coretech.kr Web: www.e-coretech.kr ~~~~~~~~~~~~~~~~~~~~~~
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/20a84ac1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/20a84ac1/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/20a84ac1/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181228/20a84ac1/attachment-0005.png>
