RTEMS POSIX Priority Inversion Issue.
JunBeom Kim (EmbedCoreTech) jbkim at e-coretech.kr
Sat Dec 29 05:24:10 UTC 2018
Dear Joel,
Thank you for your advice.
I will check this from RTEMS 4.12 and RTEMS 5.0.
After I check this, I will share update information.
Have a good weekend and Happy new year.
Best Regards,
JunBeom
Sent: Saturday, December 29, 2018 1:46 AM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr>
Cc: 구철회 <chkoo at kari.re.kr>; rtems-users at rtems.org <users at rtems.org>
Subject: Re: RTEMS POSIX Priority Inversion Issue.
Hi
I'm off for the holidays and answering from my phone. My suspicion is that the pthread command is an alias for the tasks command. Thus it is not reporting the priority from the view of the POSIX API but from the view of the Classic API. Internally all threads and tasks are instances of SuperCore threads and the priorities are mapped to what is required by the API.
Priority 1 in Classic API is 254 in POSIX.
Please investigate the code for the pthread command and see if I am right. This would be a minor bug in the shell rather than a priority inversion issue.
--joel
On Fri, Dec 28, 2018, 1:21 AM JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr <mailto:jbkim at e-coretech.kr>  wrote:
Dear Mr. Koo.
There is not any relationship between main thread and pthread1/2/3.
Main thread is run on core 1 of Cortex-A9.
Pthread1/2/3 threads is run on core 2 of Cortex-A9.
That is, both main thread and pthread1/2/3 is run on each cores independently.
Also, I used manual affinity using pthread_setaffinity_np().
Pthread1/2/3 is created by main thread.
and, actual operation is using Qt Thread API. I attached simple example code.
Qt Thread API is calling RTEMS POSIX API.
Best Regards,
JunBeom
From: chkoo at kari.re.kr <mailto:chkoo at kari.re.kr>  <chkoo at kari.re.kr <mailto:chkoo at kari.re.kr> >
Sent: Friday, December 28, 2018 4:05 PM
To: JunBeom Kim (EmbedCoreTech) <jbkim at e-coretech.kr <mailto:jbkim at e-coretech.kr> >
Cc: users at rtems.org <mailto:users at rtems.org>
Subject: RE: RTEMS POSIX Priority Inversion Issue.
What is the relation between main thread and pthread1/2/3?
If the main thread has a control to wake up each pthread1/2/3, it gonna be in trouble when the prioirty of the main thread is lower than pthread1/2/3s because the main thread has never chance to run it, which is required to other threads.
However why do you assign so much long integer value to priority?
Cheol
--------- 원본 메일 ---------
보낸사람 : "JunBeom Kim (EmbedCoreTech)" <jbkim at e-coretech.kr <mailto:jbkim at e-coretech.kr> >
받는사람 : <users at rtems.org <mailto:users at rtems.org> >
받은날짜 : 2018-12-28 (금) 15:45:48
제목 : RTEMS POSIX Priority Inversion Issue.
Dear Sir,
I am testing RTEMS POSIX thread priority.
I am still using RTEMS 4.12 in 2017 year.
There are four pthreads(main, pthread1, pthread2, pthread3) on two cores in my test case.
- main pthread is running on core 1.
- pthread1, pthread2, pthread3 is running on core 2.
- All threads are doing GPIO toggling action in while(1) loop.
- my configuration for timeslice quantum is 25ms.
As I know from RTEMS POSIX manual, there is below statement.
In the RTEMS implementation of the POSIX API, the priorities range from the low priority of
sched_get_priority_min() to the highest priority of sched_get_priority_max(). Numerically
higher values represent higher priorities.
But, when I test this, lower value is doing as higher priority. Higher value is doing as lower priority.
Is this correct operation ?
Case 0) All threads are same priority.
[/] # pthread
ID       NAME             CPU SHED PRI STATE  MODES    EVENTS WAITINFO
0b010001  main_thread       1 MEDF 2147483645 READY P:T:nA   NONE
0b010002  pthread1           2 MEDF 2147483645 READY P:T:nA   NONE
0b010003  pthread2           2 MEDF 2147483645 READY P:T:nA   NONE
0b010004  pthread3           2 MEDF 2147483645 READY P:T:nA   NONE
Case 1) pthread3 is lower priority according to manual. But, pthread3 is higher priority in my case.
[/] # pthread
0b010002  pthread1           2 MEDF 2147483646 READY P:T:nA   NONE
0b010003  pthread2           2 MEDF 2147483646 READY P:T:nA   NONE
0b010004  pthread3           2 MEDF 1789569706 READY P:T:nA   NONE
Case 2) pthread3 is higher priority according to manual. pthread1 and pthread2 are higher priority than pthread3.
[/] # pthread
0b010002  pthread1           2 MEDF 1789569706 READY P:T:nA   NONE
0b010003  pthread2           2 MEDF 1789569706 READY P:T:nA   NONE
0b010004  pthread3           2 MEDF 2147483646 READY P:T:nA   NONE
Please advise.
Best Regards,
JunBeom Kim
President / EmbedCoreTech
Phone: +82-31-396-5584
Fax: +82-504-065-5720
Mobile:+82-10-6425-5720
Email: jbkim at e-coretech.kr <mailto:jbkim at e-coretech.kr>
Web: www.e-coretech.kr <http://www.e-coretech.kr>
  <https://webmail.kari.re.kr:443/checkread/MTA2NjIz/amJraW1AZS1jb3JldGVjaC5rcg==/>
users mailing list
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20181229/d85d2142/attachment-0002.html>
