AW: Problem intializing the Network Stack
Sascha.Tetkov Sascha.Tetkov-extern at jena-optronik.de
Wed Feb 14 10:24:45 UTC 2018
It uses RTEMS 5.0
-----Ursprüngliche Nachricht-----
Von: Chris Johns [mailto:chrisj at rtems.org]
Gesendet: Mittwoch, 14. Februar 2018 00:40
An: Sascha.Tetkov; users at rtems.org
Betreff: Re: Problem intializing the Network Stack
On 14/02/2018 00:15, Sascha.Tetkov wrote:
> Hello,
> I'm currently trying to initialize the Network Stack to create a simple echo server on a LEON-4 N2X processor board. I'm using the Cobham Gaisler supplied cross-compiler (gcc with ready to use BSPs), and have already run some test applications, which means (or should mean) the toolchain works.
> My problem is that the network initialization fails. The debug information I can get is relatively scarce, but using gdb I see that it seems to crash on bsd_init (rtems_glue.c), specifically on
> 	p = rtems_bsdnet_malloc_mbuf(nmbuf * _SYS_MBUF_LEGACY_MSIZE + _SYS_MBUF_LEGACY_MSIZE - 1,MBUF_MALLOC_MBUF);
> 	p = (char *)(((uintptr_t)p + _SYS_MBUF_LEGACY_MSIZE - 1) & ~(_SYS_MBUF_LEGACY_MSIZE - 1));
> 	if (p == NULL) {
> 		printf ("Can't get network memory.\n");
> Now, the driver initialization went through, and I should have 1 Gb of memory.
> Considering I'm quite new to RTEMS, I'm not sure how to approach this issue and how to proceed on diagnosing this problem.
> Any help would be appreciated.
Which version of RTEMS are you using?
