problem about rtems source builder on windows
Tom
ventureg at 163.com
Wed Feb 14 11:58:25 UTC 2018
hi Chris,
I am using source builder to build a toolchain for arm on windows 7.
python 2.7.13 from https://www.python.org/downloads/ is installed.
But when I'm checking the environment using `source-builder/sb-check`,
error message " error: failed to load Windows host support " shows up.
So source-builder/sb/options.py line 600 went wrong.
overrides = None
if os.name == 'nt':
try:
import windows
overrides = windows.load()
host_windows = True
host_posix = False
except:
raise error.general('failed to load Windows host support')
elif os.name == 'posix':
It turns out that there is no `import windows` module.
I am wondering what package is needed to import `windows'.
Thanks in advance.
tom at shanghai
URL: <http://lists.rtems.org/pipermail/users/attachments/20180214/f5442b4b/attachment.html>
