[i386] Invalid BSP-Error without sb-bootstrap
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri Jan 5 16:18:39 UTC 2018
Hello,
We found some unexpected behavior when rebuilding the current RTEMS master for i386.
If we run the update as usual: pull current master, bootstrap, configure and finally make for i386 the compilation fails with the error
checking for RTEMS_BSP... pc386
checking for perl... /usr/bin/perl
configure: error: Invalid BSP
configure: error: ../../../../../../../rtems/c/src/lib/libbsp/i386/configure failed for lib/libbsp/i386
It also fails if one selects any other bsp.
Now we found the sb-bootstrap  command in the new documentation[1]. If I use this one the configuration and building work.
Does that mean from now on the traditional (=slow) bootstrap shouldn't be used anymore?
>From the explanation in the docs it sounds as if sb-bootstrap would do the same as bootstrap, but faster.
Best regards,
   Jan
[1] https://docs.rtems.org/branches/master/user/installation/kernel.html#bootstrapping
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
DLR.de/SC
