[i386] Invalid BSP-Error without sb-bootstrap
Joel Sherrill
joel at rtems.org
Fri Jan 5 16:38:00 UTC 2018
On Fri, Jan 5, 2018 at 10:18 AM, <Jan.Sommer at dlr.de> wrote:
> Hello,
> We found some unexpected behavior when rebuilding the current RTEMS master
> for i386.
> If we run the update as usual: pull current master, bootstrap, configure
> and finally make for i386 the compilation fails with the error
> checking for RTEMS_BSP... pc386
> checking for perl... /usr/bin/perl
> configure: error: Invalid BSP
> configure: error: ../../../../../../../rtems/c/src/lib/libbsp/i386/configure
> failed for lib/libbsp/i386
> It also fails if one selects any other bsp.
> Now we found the sb-bootstrap command in the new documentation[1]. If I
> use this one the configuration and building work.
> Does that mean from now on the traditional (=slow) bootstrap shouldn't be
> used anymore?
> From the explanation in the docs it sounds as if sb-bootstrap would do the
> same as bootstrap, but faster.
I can confirm this. sb-bootstrap produces a tree which is configurable.
Regular bootstrap
does not.
There was no intention to break the regular bootstrap. Just a bug.
--joel
> Best regards,
> Jan
> [1] https://docs.rtems.org/branches/master/user/installation/kernel.html#
> bootstrapping
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> German Aerospace Center
> Simulation and Software Technology | Software for Space Systems and
> Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> Jan Sommer
> Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
> DLR.de/SC
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180105/7eb5cfcc/attachment-0002.html>
