Device Interrupt Handler CPU Load Anaysis Method.
Fri Jan 12 06:03:48 UTC 2018
On 12/01/18 02:38, Thomas Kim wrote:
> Dear Sir,
> As I checked until now, thread(task, pthread) cpu load analysis method
> using "cpuuse" is perfect !
> At this time, I am doing multiple device interrupt hander stress
> testing. but, there is not CPU load anaysis method about multiple
> device interrupt handler.
> Is there any method for checking CPU load about multiple device
> interrupt handlers ?
The is limited support for this. You can try to use enable the profiling
option:
cpukit/sapi/include/rtems/profiling.h
For interrupt profiling a BSP support is necessary. I think it is only
implemented on ARM, PowerPC and SPARC currently.
The RTEMS trace linker is also an option.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
