RSB fails to build QEMU
Stephan Gambke s7eph4n at protonmail.com
Sun Jan 21 15:18:44 UTC 2018
Hi Rehab.
I don't think that that's the problem. I have glib installed.
I just went to https://wiki.qemu.org/Hosts/Linux and followed their instructions on building QEMU from source. No problem at all, following their instructions QEMU is running fine.
Only when I use the RSB I get the same error as before.
​Stephan
-------- Original Message --------
 On January 21, 2018 2:36 PM, Rehab Massoud <rehab.massoud at gmail.com> wrote:
>Hi Stephan,
>I think simply your problem is at the end of the attached file:
> ERROR: glib-2.22 gthread-2.0 is required to compile QEMU.
> You just need to install the library as it's named in your Linux distribution. Probably when you pass this also, another library could be missing and you will need to install it as well. On Qemu's website they're mentioning these 2 libraries as requirements.
>Best regards,
>Rehab
>On Jan 21, 2018 14:21, "Stephan Gambke" <s7eph4n at protonmail.com> wrote:
>>Hi.
>> I am new to this, so I am probably missing something obvious, but when I try to build the qemu.bset RSB fails, giving me
>> ​error: building qemu-42d58e7c6760cb9c55627c28ae538e27dcf2f144-x86_64-linux-gnu-1
>> Build FAILED
>>   See error report: rsb-report-qemu-42d58e7c6760cb9c55627c28ae538e27dcf2f144-x86_64-linux-gnu-1.txt
>> (The error report file is attached.)
>>>> Here is what I did (starting from $HOME):
>> $ mkdir -p development/rtems/sources
>> $ cd development/rtems/sources
>> $ git clone git://git.rtems.org/rtems-source-builder.git
>> $ cd rtems-source-builder/rtems/
>> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5 devel/qemu.bset
>> (Before the last step I went through the involved config files and commented out the md5 hash checks.)
>> Did I miss anything?
>> Stephan
>>_______________________________________________
>> users mailing list
>>users at rtems.org
>>http://lists.rtems.org/mailman/listinfo/users
