[i386] Invalid BSP-Error without sb-bootstrap
Jan.Sommer at dlr.de
Mon Jan 8 10:23:43 UTC 2018
TOFU:
Thank you for the fast fix, Joel.
All i386 bsps compile again with the traditional bootstrapping.
Best regards,
Jan
Sent: Friday, January 05, 2018 6:04 PM
To: Sommer, Jan
Cc: rtems-users at rtems.org
Subject: Re: [i386] Invalid BSP-Error without sb-bootstrap
On Fri, Jan 5, 2018 at 10:38 AM, Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
On Fri, Jan 5, 2018 at 10:18 AM, <Jan.Sommer at dlr.de<mailto:Jan.Sommer at dlr.de>> wrote:
Hello,
We found some unexpected behavior when rebuilding the current RTEMS master for i386.
If we run the update as usual: pull current master, bootstrap, configure and finally make for i386 the compilation fails with the error
checking for RTEMS_BSP... pc386
checking for perl... /usr/bin/perl
configure: error: Invalid BSP
configure: error: ../../../../../../../rtems/c/src/lib/libbsp/i386/configure failed for lib/libbsp/i386
It also fails if one selects any other bsp.
Now we found the sb-bootstrap command in the new documentation[1]. If I use this one the configuration and building work.
Does that mean from now on the traditional (=slow) bootstrap shouldn't be used anymore?
From the explanation in the docs it sounds as if sb-bootstrap would do the same as bootstrap, but faster.
I can confirm this. sb-bootstrap produces a tree which is configurable. Regular bootstrap
does not.
There was no intention to break the regular bootstrap. Just a bug.
I just pushed a fix. It worked for pc386 and didn't introduce any differences in acinclude.m4
so I was happy enough to push it.
If that doesn't squash it completely, just report again.
Good catch!
--joel
--joel
Best regards,
Jan
[1] https://docs.rtems.org/branches/master/user/installation/kernel.html#bootstrapping
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494<tel:%2B49%20531%20295-2494> | Telefax 0531 295-2767 | jan.sommer at dlr.de<mailto:jan.sommer at dlr.de>
DLR.de/SC
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180108/d1454089/attachment-0002.html>
