[i386] Invalid BSP-Error without sb-bootstrap
Fri Jan 5 17:03:49 UTC 2018
On Fri, Jan 5, 2018 at 10:38 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jan 5, 2018 at 10:18 AM, <Jan.Sommer at dlr.de> wrote:
>> Hello,
>> We found some unexpected behavior when rebuilding the current RTEMS
>> master for i386.
>> If we run the update as usual: pull current master, bootstrap, configure
>> and finally make for i386 the compilation fails with the error
>> checking for RTEMS_BSP... pc386
>> checking for perl... /usr/bin/perl
>> configure: error: Invalid BSP
>> configure: error: ../../../../../../../rtems/c/src/lib/libbsp/i386/configure
>> failed for lib/libbsp/i386
>> It also fails if one selects any other bsp.
>> Now we found the sb-bootstrap  command in the new documentation[1]. If I
>> use this one the configuration and building work.
>> Does that mean from now on the traditional (=slow) bootstrap shouldn't be
>> used anymore?
>> From the explanation in the docs it sounds as if sb-bootstrap would do
>> the same as bootstrap, but faster.
> I can confirm this. sb-bootstrap produces a tree which is configurable.
> Regular bootstrap
> does not.
> There was no intention to break the regular bootstrap. Just a bug.
I just pushed a fix. It worked for pc386 and didn't introduce any
differences in acinclude.m4
so I was happy enough to push it.
If that doesn't squash it completely, just report again.
Good catch!
--joel
> --joel
>> Best regards,
>>    Jan
>> [1] https://docs.rtems.org/branches/master/user/installation/
>> kernel.html#bootstrapping
>> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
>> German Aerospace Center
>> Simulation and Software Technology | Software for Space Systems and
>> Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
>> Jan Sommer
>> Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
>> DLR.de/SC
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180105/a958cdf3/attachment-0002.html>
