4.11 RSB was Re: rsb
Joel Sherrill
joel at rtems.org
Sat Jul 7 15:47:35 UTC 2018
Chris.. hoping you see this..
I started a test of 4.10 before the server was shut down to be moved
to OAR's new location yesterday but not 4.11.
On Fri, Jul 6, 2018 at 7:07 PM, Siddons, David <siddons at bnl.gov> wrote:
> The RSB installed OK. I tried to then get the 4.11 branch, assuming that
> was the latest released branch. However, it couldn't find it:
> ../source-builder/sb-set-builder --prefix=/home/peter/development/rtems/4.11
> 4.11/rtems-arm
> bash: ../source-builder/sb-set-builder: No such file or directory
> Changing 4.11 to 5 resulted in a good build. So what happened to 4.11?
> Do I now have to install the kernel source by hand, and build it like in
> the old style? I couldn't see it anywhere in the resultant tree.
> Pete.
> *From:* users <users-bounces at rtems.org> on behalf of Siddons, David <
> siddons at bnl.gov>
> *Sent:* Friday, July 6, 2018 3:24:02 PM
> *To:* joel at rtems.org
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: rsb
> I looked at the Github site, got to the 4.11 branch, and the window had an
> https link for cloning. THat seems to have worked:
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> More as I continue 😊
> Pete.
> siddons at bnl.gov>
> *Sent:* Friday, July 6, 2018 3:14:13 PM
> *Subject:* Re: rsb
> Hi Joel,
> I'm doing this from home, so not going through the BNL firewall. It has
> worked in the past, but not for the last few weeks. I made an attempt a
> while back and had partial success, then cleaned everything out and started
> again, with this result. I thought maybe something was in transition, so I
> waited until now to try again.
> Pete.
> *From:* Joel Sherrill <joel at rtems.org>
> *Sent:* Friday, July 6, 2018 3:08:52 PM
> *To:* Siddons, David
> *Subject:* Re: rsb
> On Fri, Jul 6, 2018, 2:06 PM Siddons, David <siddons at bnl.gov> wrote:
> Hi Joel,
> No it doesn't. Is it possible there's something wrong with my git
> installation?
> Any chance bnl has blocked git?
> I doubt it is something on your computer. There is supposed to be a way to
> fetch git via https which would get around firewall issues.
> Pete.
> *Sent:* Friday, July 6, 2018 2:59 PM
> *Cc:* users at rtems.org
> *Subject:* Re: rsb
> Hi
> By any chance does it work for you now? At least one of the servers
> was being bombarded yesterday and ran out of disk space with logs.
> This worked for me today with no hiccups.
> --joel
> On Fri, Jul 6, 2018 at 1:41 PM, Siddons, David <siddons at bnl.gov> wrote:
> I just tried again to clone rsb:
> ~/development/rtems$ git clone git://git.rtems.org/rtems-
> Cloning into 'rsb'...
> fatal: repository 'https://git.rtems.org//rtems-source-builder.git/' not
> found
> Looking at the contents of this link gets:
> No repositories found
> I found this same clone command in various places throughout the RTEMS
> documentation. Am I doing something wrong?
> Pete.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180707/294d8528/attachment.html>
