rsb
Siddons, David siddons at bnl.gov
Sat Jul 7 00:07:12 UTC 2018
The RSB installed OK. I tried to then get the 4.11 branch, assuming that was the latest released branch. However, it couldn't find it:
../source-builder/sb-set-builder --prefix=/home/peter/development/rtems/4.11 4.11/rtems-arm
bash: ../source-builder/sb-set-builder: No such file or directory
Changing 4.11 to 5 resulted in a good build. So what happened to 4.11?
Do I now have to install the kernel source by hand, and build it like in the old style? I couldn't see it anywhere in the resultant tree.
Pete.
________________________________
From: users <users-bounces at rtems.org> on behalf of Siddons, David <siddons at bnl.gov>
Sent: Friday, July 6, 2018 3:24:02 PM
To: joel at rtems.org
Cc: rtems-users at rtems.org
Subject: Re: rsb
I looked at the Github site, got to the 4.11 branch, and the window had an https link for cloning. THat seems to have worked:
git clone https://github.com/RTEMS/rtems-source-builder.git rsb
More as I continue 😊
Pete.
Sent: Friday, July 6, 2018 3:14:13 PM
Subject: Re: rsb
Hi Joel,
  I'm doing this from home, so not going through the BNL firewall. It has worked in the past, but not for the last few weeks. I made an attempt a while back and had partial success, then cleaned everything out and started again, with this result. I thought maybe something was in transition, so I waited until now to try again.
Pete.
Sent: Friday, July 6, 2018 3:08:52 PM
To: Siddons, David
Subject: Re: rsb
On Fri, Jul 6, 2018, 2:06 PM Siddons, David <siddons at bnl.gov<mailto:siddons at bnl.gov>> wrote:
Hi Joel,
   No it doesn't. Is it possible there's something wrong with my git installation?
Any chance bnl has blocked git?
I doubt it is something on your computer. There is supposed to be a way to fetch git via https which would get around firewall issues.
Pete.
From: Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>>
Sent: Friday, July 6, 2018 2:59 PM
To: Siddons, David
Cc: users at rtems.org<mailto:users at rtems.org>
Subject: Re: rsb
Hi
By any chance does it work for you now? At least one of the servers
was being bombarded yesterday and ran out of disk space with logs.
This worked for me today with no hiccups.
--joel
On Fri, Jul 6, 2018 at 1:41 PM, Siddons, David <siddons at bnl.gov<mailto:siddons at bnl.gov>> wrote:
I just tried again to clone rsb:
~/development/rtems$ git clone git://git.rtems.org/rtems-source-builder.git<http://git.rtems.org/rtems-source-builder.git> rsb
Cloning into 'rsb'...
fatal: repository 'https://git.rtems.org//rtems-source-builder.git/' not found
Looking at the contents of this link gets:
No repositories found
I found this same clone command in various places throughout the RTEMS documentation. Am I doing something wrong?
Pete.
users mailing list
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180707/7a6f88a9/attachment-0002.html>
