rsb
Russell Haley russ.haley at gmail.com
Fri Jul 6 21:47:46 UTC 2018
On Fri, Jul 6, 2018 at 12:28 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jul 6, 2018 at 2:24 PM, Siddons, David <siddons at bnl.gov> wrote:
>> I looked at the Github site, got to the 4.11 branch, and the window had
>> an https link for cloning. THat seems to have worked:
>> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> Weird. I would expect both to work from home. Even a new home router
> wouldn't
> get in the way of something like that.
>> More as I continue 😊
> Weird that you are at home and having trouble. That's usually where
> everything works. :(
> On an odd note, I had an 8-port switch die in my house this week. Was the
> last
> thing I expected to have broken. Got a new one and then my son plugged both
> ends of a cable into the new switch and the network here suffered greatly.
I once saw a situation where an intern plug a cable dangling from one port
into the empty port sitting next to it. The entire network went into total
meltdown. Luckily when someone from the IT group was going for a
replacement router happened to notice the "odd wiring" an unplugged it. The
luck was that the spare router was in a storage room next to where the
offending cable was.
Russ
> In
> the end, we found a number of cables that weren't needed anymore but we
> had never untangled them to remove them.
> Also installed an access point attached to the far end of the wired network
> and that has helped some of the weak signal points.
>> Pete.
>> *From:* users <users-bounces at rtems.org> on behalf of Siddons, David <
>> siddons at bnl.gov>
>> *Sent:* Friday, July 6, 2018 3:14:13 PM
>> *To:* joel at rtems.org
>> *Cc:* rtems-users at rtems.org
>> *Subject:* Re: rsb
>> Hi Joel,
>>   I'm doing this from home, so not going through the BNL firewall. It has
>> worked in the past, but not for the last few weeks. I made an attempt a
>> while back and had partial success, then cleaned everything out and started
>> again, with this result. I thought maybe something was in transition, so I
>> waited until now to try again.
>> Pete.
>> *From:* Joel Sherrill <joel at rtems.org>
>> *Sent:* Friday, July 6, 2018 3:08:52 PM
>> *To:* Siddons, David
>> *Subject:* Re: rsb
>> On Fri, Jul 6, 2018, 2:06 PM Siddons, David <siddons at bnl.gov> wrote:
>> Hi Joel,
>>    No it doesn't. Is it possible there's something wrong with my git
>> installation?
>> Any chance bnl has blocked git?
>> I doubt it is something on your computer. There is supposed to be a way
>> to fetch git via https which would get around firewall issues.
>> Pete.
>> *Sent:* Friday, July 6, 2018 2:59 PM
>> *Cc:* users at rtems.org
>> *Subject:* Re: rsb
>> Hi
>> By any chance does it work for you now? At least one of the servers
>> was being bombarded yesterday and ran out of disk space with logs.
>> This worked for me today with no hiccups.
>> --joel
>> On Fri, Jul 6, 2018 at 1:41 PM, Siddons, David <siddons at bnl.gov> wrote:
>> I just tried again to clone rsb:
>> ~/development/rtems$ git clone git://git.rtems.org/rtems-sour
>> ce-builder.git rsb
>> Cloning into 'rsb'...
>> fatal: repository 'https://git.rtems.org//rtems-source-builder.git/' not
>> found
>> Looking at the contents of this link gets:
>> No repositories found
>> I found this same clone command in various places throughout the RTEMS
>> documentation. Am I doing something wrong?
>> Pete.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180706/5c9d7900/attachment-0002.html>
