Format flash chip with FAT
Tue Jun 5 11:09:25 UTC 2018
On 05/06/18 13:03, LINDOW, Phil wrote:
>> Why do you want to use a FAT file system on a flash instead of JFFS2?
>> With the functions you have, you have all what you need to use JFFS2.
> Because the file system should be compatible with RTEMS, VxWorks and in the best case PikeOS.
> I know that FAT is not the best choice for flash but I am afraid FAT is the only file system that is integrated in all three of them.
The JFFS2 code should be easy to port to VxWorks or PikeOS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
