Error building libbsd
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 22 10:22:59 UTC 2018
Hello Niko,
from a quick glance, everything till the waf call looks good. What is
really odd is the output of the last waf-2.0.8 call. There should be a
lot more output starting with something like
Waf: Entering directory
`/home/EB/christian_m/Projekte/some-project/rtems-libbsd/build/arm-rtems5-atsamv-everything'
[  1/122] Creating
build/arm-rtems5-atsamv-everything/build-include/rtems/bsd/modules.h
[  2/122] Compiling rtemsbsd/rtems/generate_kvm_symbols
[  3/122] Compiling testsuite/include/rtems/bsd/test/network-config.h.in
[  4/122] Compiling freebsd/sys/crypto/blowfish/bf_locl.h
[  5/122] Compiling freebsd/sys/crypto/blowfish/bf_pi.h
You are even missing the "Waf: Entering directory". So that seems like a
quite early bug.
You can try whether a `waf -v` provides more output. Beneath that: Where
does your waf come from? You call it with a version number.
Best regards
Christian Mauderer
Am 22.06.2018 um 11:21 schrieb Nicolas Tsiogkas:
> Hi,
> I did the process again with no luck. I am attaching a zip with command
> outputs/logs.
> Regards,
> Niko
> On Fri, Jun 22, 2018 at 9:44 AM Nicolas Tsiogkas <lou.nick at gmail.com
> <mailto:lou.nick at gmail.com>> wrote:
>     Hi Christian,
>     it is a fresh clone. Although I had a previous build with 4.11 I
>     decided try from scratch given the changes.
>     Error is during the build. I'm configuring normally and when I try
>     to waf it then it fails.
>     Is there any way to increase the verbosity? I will repeat all the
>     process from scratch keeping logs so I can send them and try to find
>     the issue.
>     Thanks for your time!
>     Regards,
>     Niko
>     On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>         Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
>         > And apparently I forgot the host.
>         > It is ubuntu 16.04:
>         > Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP
>         Wed May 30
>         > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
>         > gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
>         > N.
>         > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas
>         <lou.nick at gmail.com <mailto:lou.nick at gmail.com>
>         > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>> wrote:
>         >     Hi Joel,
>         >      waf-2.0.8 configure --prefix="$sandbox/5"
>         >     --rtems-bsps=arm/xilinx_zynq_a9_qemu
>         >     has the following output:
>         >     Setting top to                           :
>         >     /home/niko/sandbox/rtems-libbsd
>         >     Setting out to                           :
>         >     /home/niko/sandbox/rtems-libbsd/build
>         >     RTEMS Version                            : 5
>         >     Architectures                            : arm-rtems5
>         >     Board Support Package                    :
>         >     arm-rtems5-xilinx_zynq_a9_qemu
>         >     Show commands                            : no
>         >     Long commands                            : no
>         >     Checking for program 'arm-rtems5-gcc'    :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-gcc
>         >     Checking for program 'arm-rtems5-g++'    :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-g++
>         >     Checking for program 'arm-rtems5-ld'     :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-ld
>         >     Checking for program 'arm-rtems5-ar'     :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-ar
>         >     Checking for program 'arm-rtems5-nm'     :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-nm
>         >     Checking for program 'arm-rtems5-objdump' :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-objdump
>         >     Checking for program 'arm-rtems5-objcopy' :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-objcopy
>         >     Checking for program 'arm-rtems5-readelf' :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-readelf
>         >     Checking for program 'arm-rtems5-strip'   :
>         >     /home/niko/sandbox/5/bin/arm-rtems5-strip
>         >     Checking for program 'rtems-ld'           :
>         >     /home/niko/sandbox/5/bin/rtems-ld
>         >     Checking for program 'rtems-tld'          :
>         >     /home/niko/sandbox/5/bin/rtems-tld
>         >     Checking for program 'rtems-bin2c'        :
>         >     /home/niko/sandbox/5/bin/rtems-bin2c
>         >     Checking for program 'tar'                : /bin/tar
>         >     Checking for program 'gcc, cc'            :
>         >     Checking for program 'ar'                 :
>         >     Checking for program 'g++, c++'           :
>         >     Checking for program 'gas, gcc'           :
>         >     Compiler version (arm-rtems5-gcc)         : 7.3.0 20180125
>         (RTEMS 5,
>         >     RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
>         >     Checking for RTEMS CPU options header     : started
>         >     -> processing test results                : all ok
>         >     Checking for RTEMS_DEBUG                  : no
>         >     Checking for RTEMS_MULTIPROCESSING        : no
>         >     Checking for RTEMS_NEWLIB                 : yes
>         >     Checking for RTEMS_POSIX_API              : yes
>         >     Checking for RTEMS_SMP                    : no
>         >     Checking for RTEMS_NETWORKING             : no
>         >     Checking for RTEMS header                 : started
>         >     Checking for header dlfcn.h               : yes
>         >     Checking for header rtems/pci.h           : yes
>         >     Configure variant:                        :
>         >     arm-rtems5-xilinx_zynq_a9_qemu-default
>         >     Checking for header rtems/rtems-debugger.h : yes
>         >     'configure' finished successfully (0.744s)
>         >     Cheers,
>         >     Niko
>         >     On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill
>         <joel at rtems.org <mailto:joel at rtems.org>
>         >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>         >         On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
>         >             Hi,
>         >             following the steps described
>         >             in https://github.com/RTEMS/rtems-libbsd I get an
>         error
>         >             "Could not create the directory ///h" while trying
>         to build
>         >             with waf 2.0.8
>         >             Is it a known problem?
>         >         Not to me.
>         >         What's your configure command and host?
>         >             I have seen that the installation procedure has
>         changed
>         >             since 4.11 and now the tools and the bsps are
>         installed in
>         >             the same prefix, but that shouldn't matter I suppose.
>         >             Thank you in advance.
>         >             Regards,
>         >             Niko
>         >             _______________________________________________
>         >             users mailing list
>         >             users at rtems.org <mailto:users at rtems.org>
>         <mailto:users at rtems.org <mailto:users at rtems.org>>
>         >             http://lists.rtems.org/mailman/listinfo/users
>         > users mailing list
>         Hello Nicolas,
>         I also don't know that problem. The directory that should be created
>         "///h" looks like there are some variables missing between the
>         slashes.
>         But I'm not aware of any directory h that should be created
>         somewhere.
>         - Did you upgrade from a earlier build or do you build in a fresh
>         checkout? There have been some changes to the build system in
>         the last
>         months that have lead to incompatible cache files. If it is an
>         old tree,
>         try to remove `build` and `.lock-waf_*`.
>         - About when does the problem happen? It seems your configure
>         runs fine.
>         So I assume that it appears during build or install. Maybe you could
>         provide some lines of context to the error message?
>         Best regards
>         Christian Mauderer
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
