RISC-V RTEMS Support
Molock, Dwaine S. (GSFC-5820)
dwaine.s.molock at nasa.gov
Tue Jun 12 19:13:26 UTC 2018
Hi Sebastian,
Will these ports work on the RISC-V designs from SiFive (https://www.sifive.com)?
Thanks,
Dwaine
On Jun 12, 2018, at 9:25 AM, Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
Hello Molock,
we work currently on the SMP support for RISC-V (32-bit and 64-bit). The aim is to run the tests on Qemu and a FPGA Board with two BOOMv2 processors.
https://devel.rtems.org/ticket/3433
My current task is a tool chain update to include a bug fix for:
https://sourceware.org/bugzilla/show_bug.cgi?id=23244
This fix is necessary to run 64-bit applications in an address rage above 0x80000000 (SDRAM address in some standard chips). We need also specialized GCC multilibs for this.
I would like to merge the riscv32 and riscv64 tool chain into one riscv tool chain. There was some discussion necessary with the RISC-V maintainers to achieve this.
The overall work should be finished in two to three months.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20180612/e51d0a88/attachment-0002.html>
