Task context information available on crash
Tue Mar 20 11:55:28 UTC 2018
On 20/03/18 11:49, Matthew J Fletcher wrote:
> Thank you for the advice.
> So i can see that the executing task was "TIME", which is the timer
> server. So the problem is almost certainly a bad function pointer
> passed as the routine to invoke.
> I can place a breakpoint in timerserver.c, but the crash is after
> several minutes (and many tens of thousands of timer operations).
> I think i will have to modify _Timer_server_Body() to copy the timer
> id to a global variable so i can inspect it after an exception.
> Unless there is a better way ?
A more complicated solution might be the RTEMS trace linker:
https://devel.rtems.org/wiki/Developer/Tracing/Trace_Linker
I am not sure if ARMv7-M is supported.
You can also use a hardware tracer if available.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
