Interrupt latency in RTEMS (Zedboard)
BRIARD Sebastien
sebastien.briard at thalesaleniaspace.com
Tue Mar 27 11:30:12 UTC 2018
De : BRIARD Sebastien
Envoyé : mardi 27 mars 2018 11:42
À : 'users at rtems.org'
Objet : Interrupt latency in RTEMS (Zedboard)
Hi,
I was trying to measure the interrupt latency in RTEMS with a Xilinx Zynq Zedboard (cortex A9).
I modified the c file in classic_signal example to measure time in the main loop and right after entering the handler.
That might seem artificial but well, it gives me a value with a relatively simple code.
I used this code for 100, 10000, and one million ticks per second. I am trying to understand how the measure can quite equal with 100 ticks per second and a million.
(I obtained values between 500ns and 1000ns).
Is there another timer that is used for interrupt processing ?
A subsequent question, is it possible to use a larger value than a tick per microsecond ? Maybe I am confusing a little between frequency and tick clock in RTEMS but I would like to run test with more or less a tick per nanosecond.
Thank you,
Sébastien.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180327/14a3a6a9/attachment.html>
