Crash deep in heap allocation for rtems_region_get_segment() call
Matthew J Fletcher
amimjf at gmail.com
Fri Mar 9 13:37:34 UTC 2018
Gedare / Sebastian,
Thank you for your advice, --enable-rtems-debug and then using malloc_walk()
helps to investigate the issue.
On 7 March 2018 at 14:47, Sebastian Huber <
> Hello Matthew,
> it is very likely not a bug in the heap code. It is probably a use after
> free or heap block overwrite. You can use the --enable-rtems-debug
> configuration option to enable a heap protections which helps to catch
> these application errors.
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20180309/3df8db42/attachment-0002.html>
