Quickstart Build instructions
Russell Haley russ.haley at gmail.com
Fri Mar 30 06:05:14 UTC 2018
Thanks Joel. I haven't looped back to test if it was my mistake or
something else so I'll assume my mistake for now.
Either way, I'm able to build and run the examples_v2 repository against
erc32, so... YAY!
I'd like to build Lua 5.3, do I just build the static lib "a" file and
include it in a test application? Would that happen in RTEMS proper or in
waf? I need sleep now but any suggestions would be grand.
Thanks!
Russ
On Wed, Mar 28, 2018 at 6:48 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Mar 28, 2018 at 12:51 AM, Russell Haley <russ.haley at gmail.com>
> wrote:
>> ---------- Forwarded message ----------
>> From: Russell Haley <russ.haley at gmail.com>
>> Date: Tue, Mar 27, 2018 at 10:45 PM
>> Subject: Re: Quickstart Build instructions
>> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> On Tue, Mar 27, 2018 at 10:36 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Please send e-mails to the mailing list.
>> Sorry, my mistake.
>>> On 28/03/18 07:34, Russell Haley wrote:
>>>> Where did the directory 5 come from in these instructions? Are you
>>>> missing a mkdir?
>>> The
>>> --prefix=/usr/home/chris/development/rtems/5
>>> directory is created by the sb-set-builder. It is the base installation
>>> directory.
>> I was getting a directory not writeable error until I created the folder
>> myself (even after correcting for my username). I'll try again later, but
>> it builds if I create the 5/ directory.
> What is your $HOME? Mine is usually /home/joel. If yours is similar, then
> not being able to write into /usr as non-root is expected.
> Perhaps the documentation should say ${HOME}/development/rtems/5?
> FWIW Around OAR, we tend to use ${HOME}/rtems-work/tools/5 or for
> wider deployments /rtems/5
> --joel
>> Thanks,
>> Russ
>>> $cd
>>>> $ mkdir -p development/rtems
>>>> $cd  development/rtems
>>>> $ git clone git://git.rtems.org/rtems-source-builder.git <
>>>> http://git.rtems.org/rtems-source-builder.git>  rsb
>>>> $cd  rsb
>>>> $ ./source-builder/sb-check
>>>> $cd  rtems
>>>> $ ../source-builder/sb-set-builder\
>>>>      --prefix=/usr/home/chris/development/rtems/55/rtems-sparc
>>>> Thanks,
>>>> Russ
>>>> On Tue, Mar 27, 2018 at 10:28 PM, Russell Haley <russ.haley at gmail.com
>>>> <mailto:russ.haley at gmail.com>> wrote:
>>>>     Thanks!
>>>>     Russ
>>>>     On Tue, Mar 27, 2018 at 10:23 PM, Sebastian Huber
>>>>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>>         On 28/03/18 07:14, Russell Haley wrote:
>>>>             Hi, the quick start indicates using ./bootstrap -p, but
>>>>             using said parameter only results in the error/hep output.
>>>>             Using ./bootstrap without any parameters started the the
>>>>             process for me?
>>>>             https://docs.rtems.org/branche
>>>> s/master/user/start/index.html
>>>>             <https://docs.rtems.org/branch
>>>> es/master/user/start/index.html>
>>>>         Sorry for the confusion. I updated the documentation:
>>>>         https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1b
>>>> 94f79617d850d2b0f161c00e
>>>>         <https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1
>>>> b94f79617d850d2b0f161c00e>
>>>>         --         Sebastian Huber, embedded brains GmbH
>>>>         Address : Dornierstr. 4, D-82178 Puchheim
>>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim&entry=gmail&source=g>
>>>>         <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+P
>>>> uchheim,&entry=gmail&source=g>
>>>>         Germany
>>>>         Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%204
>>>> 1-16>
>>>>         Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%204
>>>> 1-09>
>>>>         E-Mail  : sebastian.huber at embedded-brains.de
>>>>         PGP     : Public key available on request.
>>>>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>         des EHUG.
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180329/45353d01/attachment-0002.html>
