Is an example of TCP/IP on RTEMS i386 QEMU platform available?
구철회 chkoo at kari.re.kr
Fri May 18 05:12:51 UTC 2018
Hello,
I am trying to test the TCP/IP on RTEMS. And I found the virtualbox image (provided by Joel Sherrill on 2012, https://sourceforge.net/projects/rtems-vms/files/Centos-6.3-RTEMS-4.11-20121128/) is a good starting point to begin the test. It has RTEMS i386 bsp and QEMU emulator, and some examples run flawlessly.
I like to test TCP/IP application on the RTEMS i386 + QEMU environment. It seems it is possible by using ne2k_isa or ne2k_pci, or virtio on QEMU, but I found no complete QEMU setup or example of source by search
Is there any reference to those QEMU setup & example source for TCP/IP on the RTEMS i386 on QEMU?
Cheol
URL: <http://lists.rtems.org/pipermail/users/attachments/20180518/3b1e6041/attachment-0001.html>
