Is an example of TCP/IP on RTEMS i386 QEMU platform available?
Joel Sherrill
joel at rtems.org
Fri May 18 22:14:25 UTC 2018
Chris Johns has posted about his setup.
With the legacy and new TCP/IP stack, you can use PCI NICs in qemu. The
set supported varies. In the new stack, virtually everything is supported.
The command used in that ancient VM is basically still correct. Just change
the NIC to match say an Intel EtherExpress Pro and make sure the stack
is configured with it.
My recollection is that the ne2k didn't work the last time I tried it years
ago
and I suspected it was a problem in qemu since our code hadn't changed.
On Fri, May 18, 2018 at 12:12 AM, 구철회 <chkoo at kari.re.kr> wrote:
> Hello,
> I am trying to test the TCP/IP on RTEMS. And I found the virtualbox image
> (provided by Joel Sherrill on 2012, https://sourceforge.net/
> projects/rtems-vms/files/Centos-6.3-RTEMS-4.11-20121128/) is a good
> starting point to begin the test. It has RTEMS i386 bsp and QEMU emulator,
> and some examples run flawlessly.
> I like to test TCP/IP application on the RTEMS i386 + QEMU environment. It
> seems it is possible by using ne2k_isa or ne2k_pci, or virtio on QEMU, but
> I found no complete QEMU setup or example of source by search
> Is there any reference to those QEMU setup & example source for TCP/IP on
> the RTEMS i386 on QEMU?
> Cheol
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180518/6f7a746d/attachment-0002.html>
