rsb problem with python
Amaan Cheval
amaan.cheval at gmail.com
Mon May 28 22:05:06 UTC 2018
Hey David!
It looks to me like Anaconda doesn't install the "alias" binaries
specifying the version (for eg. both "python" and "python3.6"). I believe
the fix in your case should be as simple as copying your existing binary
with the following command:
cp /home/peter/miniconda3/bin/python /home/peter/miniconda3/bin/python3.6
On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> wrote:
> While building rsb for arm-rtems I got this problem:
> checking for python... /home/peter/miniconda3/bin/python
> checking for python3.6... no
> configure: error: python is missing or unusable
> Makefile:9095: recipe for target 'configure-gdb' failed
> make[1]: *** [configure-gdb] Error 1
> make[1]: Leaving directory
> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
> Makefile:848: recipe for target 'all' failed
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex
> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
> error: building
> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
> I am running Ubuntu:
> peter at peter-Latitude-E7240:/etc$ lsb_release -a
> LSB Version:
> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
> Distributor ID: Ubuntu
> Description: Ubuntu 16.04.4 LTS
> Release: 16.04
> Codename: xenial
> then:
> python -V
> Python 3.6.1 :: Continuum Analytics, Inc.
> This comes from an Anaconda installation. If I remove the path entry which
> causes that I get python 2.7, which is the default Ubuntu 16.04 version. Do
> I need to install Python 3.6?
> Pete.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180529/0e30c6bd/attachment.html>
