rtems watchdogs
Matthew J Fletcher amimjf at gmail.com
Tue May 29 16:41:46 UTC 2018
Hi,
Is there an integrated watchdog in rtems ?, i noticed that rtems seems to
implement an internal task/timer based watchdog, thats used by POSIX and
classic timers. The spwatchdog test seems to provide a good example of its
usage.
There are many BSPs that use a hardware watchdog, but no rtems code would
kick it (unless there is some hook i have not seen),. so it would have to
be set reasonably slowly 1second+ (??) so ensure no OS code false triggers.
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20180529/7b1cd001/attachment.html>
