rtems watchdogs
Joel Sherrill
joel at rtems.org
Tue May 29 22:54:21 UTC 2018
On Tue, May 29, 2018 at 11:41 AM, Matthew J Fletcher <amimjf at gmail.com>
wrote:
> Hi,
> Is there an integrated watchdog in rtems ?, i noticed that rtems seems to
> implement an internal task/timer based watchdog, thats used by POSIX and
> classic timers. The spwatchdog test seems to provide a good example of its
> usage.
> There are many BSPs that use a hardware watchdog, but no rtems code would
> kick it (unless there is some hook i have not seen),. so it would have to
> be set reasonably slowly 1second+ (??) so ensure no OS code false triggers.
There is a bit of framework to support a HW watchdog. It was intended to
install
a driver with an initialization entry along with an ioctl to stop, start,
and tickle it.
Looking today, I don't see any users of this in the tree anymore The Leon3
has
some methods to manage its watchdog.
I am certainly up for proposals on updating/replacing this interface since
it
wouldn't impact much in the tree and wouldn't take much to hook to the
Leon3.
-joel
> regards
> Matthew J Fletcher
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180529/a2cf4fca/attachment-0002.html>
