rsb problem with python
Slide
slide.o.mix at gmail.com
Wed May 30 15:49:40 UTC 2018
I ran into a similar issue and the way I solved it was by installing the
-dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
sure how to do that with the Anaconda installation, but this may help point
you in the right direction.
Regards,
Alex
On Wed, May 30, 2018 at 6:57 AM Gedare Bloom <gedare at rtems.org> wrote:
> Pete,
> Do you get anything with:
> $ which python3.6
> Probably, it is looking for that invocation command. I ought to try
> this, because my Ubuntu does not ship with python3.6 I know, so maybe
> it breaks too... hm
> On Mon, May 28, 2018 at 6:23 PM, Siddons, David <siddons at bnl.gov> wrote:
> > Hi Amaan,
> > Actually, /home/peter/miniconda3/bin/python is a soft link to
> > /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
> > Pete.
> > ________________________________
> > From: Amaan Cheval [amaan.cheval at gmail.com]
> > Sent: Monday, May 28, 2018 6:05 PM
> > To: Siddons, David
> > Cc: users at rtems.org
> > Subject: Re: rsb problem with python
> > Hey David!
> > It looks to me like Anaconda doesn't install the "alias" binaries
> specifying
> > the version (for eg. both "python" and "python3.6"). I believe the fix in
> > your case should be as simple as copying your existing binary with the
> > following command:
> > cp /home/peter/miniconda3/bin/python /home/peter/miniconda3/bin/python3.6
> > On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> wrote:
> >> While building rsb for arm-rtems I got this problem:
> >> checking for python... /home/peter/miniconda3/bin/python
> >> checking for python3.6... no
> >> configure: error: python is missing or unusable
> >> Makefile:9095: recipe for target 'configure-gdb' failed
> >> make[1]: *** [configure-gdb] Error 1
> >> make[1]: Leaving directory
> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
> >> Makefile:848: recipe for target 'all' failed
> >> make: *** [all] Error 2
> >> shell cmd failed: /bin/sh -ex
> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
> >> error: building
> >> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240
> :~/development/rtems/src/rtems-source-builder/rtems$
> >> I am running Ubuntu:
> >> peter at peter-Latitude-E7240:/etc$ lsb_release -a
> >> LSB Version:
> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
> >> Distributor ID: Ubuntu
> >> Description: Ubuntu 16.04.4 LTS
> >> Release: 16.04
> >> Codename: xenial
> >> then:
> >> python -V
> >> Python 3.6.1 :: Continuum Analytics, Inc.
> >> This comes from an Anaconda installation. If I remove the path entry
> which
> >> causes that I get python 2.7, which is the default Ubuntu 16.04
> version. Do
> >> I need to install Python 3.6?
> >> Pete.
> >> _______________________________________________
> >> users mailing list
> >> users at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180530/50213cf8/attachment-0001.html>
