rsb problem with python
Wed May 30 16:12:13 UTC 2018
Alex,
Yes that also makes sense, thank you. Usually, I've seen that problem
manifest as missing Python.h, but error messages can be vague and
inconsistent. :)
On Wed, May 30, 2018 at 11:49 AM, Slide <slide.o.mix at gmail.com> wrote:
> I ran into a similar issue and the way I solved it was by installing the
> -dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
> sure how to do that with the Anaconda installation, but this may help point
> you in the right direction.
> Regards,
> Alex
> On Wed, May 30, 2018 at 6:57 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Pete,
>> Do you get anything with:
>> $ which python3.6
>> Probably, it is looking for that invocation command. I ought to try
>> this, because my Ubuntu does not ship with python3.6 I know, so maybe
>> it breaks too... hm
>> On Mon, May 28, 2018 at 6:23 PM, Siddons, David <siddons at bnl.gov> wrote:
>> > Hi Amaan,
>> >    Actually,  /home/peter/miniconda3/bin/python is a soft link to
>> > /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
>> > Pete.
>> > ________________________________
>> > From: Amaan Cheval [amaan.cheval at gmail.com]
>> > Sent: Monday, May 28, 2018 6:05 PM
>> > To: Siddons, David
>> > Cc: users at rtems.org
>> > Subject: Re: rsb problem with python
>> > Hey David!
>> > It looks to me like Anaconda doesn't install the "alias" binaries
>> > specifying
>> > the version (for eg. both "python" and "python3.6"). I believe the fix
>> > in
>> > your case should be as simple as copying your existing binary with the
>> > following command:
>> > cp /home/peter/miniconda3/bin/python
>> > On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> wrote:
>> >> While building rsb for arm-rtems I got this problem:
>> >> checking for python... /home/peter/miniconda3/bin/python
>> >> checking for python3.6... no
>> >> configure: error: python is missing or unusable
>> >> Makefile:9095: recipe for target 'configure-gdb' failed
>> >> make[1]: *** [configure-gdb] Error 1
>> >> make[1]: Leaving directory
>> >> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>> >> Makefile:848: recipe for target 'all' failed
>> >> make: *** [all] Error 2
>> >> shell cmd failed: /bin/sh -ex
>> >> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>> >> error: building
>> >> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>> >> I am running Ubuntu:
>> >> peter at peter-Latitude-E7240:/etc$ lsb_release -a
>> >> LSB Version:
>> >> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>> >> Distributor ID: Ubuntu
>> >> Description:    Ubuntu 16.04.4 LTS
>> >> Release:        16.04
>> >> Codename:       xenial
>> >> then:
>> >> python -V
>> >> Python 3.6.1 :: Continuum Analytics, Inc.
>> >> This comes from an Anaconda installation. If I remove the path entry
>> >> which
>> >> causes that I get python 2.7, which is the default Ubuntu 16.04
>> >> version. Do
>> >> I need to install Python 3.6?
>> >> Pete.
>> >> _______________________________________________
>> >> users mailing list
>> >> users at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/users
>> > users mailing list
>> > users at rtems.org
>> users mailing list
>> users at rtems.org
