GSOC'18 project description
Tue May 1 09:34:18 UTC 2018
----- Am 1. Mai 2018 um 5:38 schrieb Chris Johns chrisj at rtems.org:
> On 30/04/2018 20:05, Sebastian Huber wrote:
>>> 3) Investigate the importance of live tracing functionality and addition of
>>> kernel level tracing. I will design both possibilities and decide which one to
>>> work on by the end of phase 1 of my evaluation.
>> I work currently on a new low level infrastructure to support gathering of
>> thread (create, delete, terminate, switch) and interrupt (entry, exit) events.
>> Similar to the capture engine, but with less overhead.
> Why not improve the existing code?
There are some problems with the capture engine in terms of data structures, synchronization, timestamping and the API.
* The sizeof(rtems_capture_record) is 20 bytes, I use only 12 bytes (16 on a 64-bit machine). I want to record high frequency events, so this 33% reduction makes a difference.
* Synchronization is done via atomic read-modify-write operations (ticket locks). The alternative implementation simply uses interrupt disable/enable.
* The timestamps use 64-bits and by default rtems_clock_get_uptime_nanoseconds() is used. This function has a high overhead for this purpose. The alternative implementation uses a 32-bit timestamp and the CPU counter. The uptime and CPU counter values are synchronized via a periodic event.
* Variable size records need more logic (branches) than fixed size records.
> Does this create a new interface and management structure?
> Do you have the requirements for this design documented anywhere?
There is not much to design. I just need a single producer single consumer queue (ring buffer) per processor. Here is the assembler code of the main function:
typedef CPU_Uint32ptr rtems_record_data;
#define RTEMS_RECORD_EVENT_EXTRA( domain, extra ) \
  ( ( ( extra ) << 6 ) | ( domain ) )
typedef enum {
#define RECORD_EVENT_SYSTEM_0( extra ) \
  RTEMS_RECORD_EVENT_EXTRA( 0, extra )
  RTEMS_RECORD_EVENT_OVERFLOW = RECORD_EVENT_SYSTEM_0( 0 ),
  RTEMS_RECORD_EVENT_UPTIME_LOW = RECORD_EVENT_SYSTEM_0( 1 ),
  RTEMS_RECORD_EVENT_UPTIME_HIGH = RECORD_EVENT_SYSTEM_0( 2 ),
  RTEMS_RECORD_EVENT_PROCESSOR = RECORD_EVENT_SYSTEM_0( 3 ),
  RTEMS_RECORD_EVENT_THREAD_CREATED = RECORD_EVENT_SYSTEM_0( 4 ),
  RTEMS_RECORD_EVENT_THREAD_CREATED_BY = RECORD_EVENT_SYSTEM_0( 5 ),
  RTEMS_RECORD_EVENT_THREAD_SWITCH = RECORD_EVENT_SYSTEM_0( 6 ),
  RTEMS_RECORD_EVENT_THREAD_DELETED = RECORD_EVENT_SYSTEM_0( 7 ),
  RTEMS_RECORD_EVENT_THREAD_DELETED_BY = RECORD_EVENT_SYSTEM_0( 8 ),
  RTEMS_RECORD_EVENT_THREAD_TERMINATED = RECORD_EVENT_SYSTEM_0( 9 ),
  RTEMS_RECORD_EVENT_INTERUPT_INSTALL = RECORD_EVENT_SYSTEM_0( 10 ),
  RTEMS_RECORD_EVENT_INTERUPT_REMOVE = RECORD_EVENT_SYSTEM_0( 11 ),
  RTEMS_RECORD_EVENT_INTERUPT_BEGIN = RECORD_EVENT_SYSTEM_0( 12 ),
  RTEMS_RECORD_EVENT_INTERUPT_END = RECORD_EVENT_SYSTEM_0( 13 ),
  /* Reserved system event domains */
  RTEMS_RECORD_EVENT_SYSTEM_0 = 0,
  RTEMS_RECORD_EVENT_SYSTEM_1,
  RTEMS_RECORD_EVENT_SYSTEM_2,
  RTEMS_RECORD_EVENT_SYSTEM_3,
  RTEMS_RECORD_EVENT_SYSTEM_4,
  RTEMS_RECORD_EVENT_SYSTEM_5,
  RTEMS_RECORD_EVENT_SYSTEM_6,
  RTEMS_RECORD_EVENT_SYSTEM_7,
  RTEMS_RECORD_EVENT_SYSTEM_8,
  RTEMS_RECORD_EVENT_SYSTEM_9,
  RTEMS_RECORD_EVENT_SYSTEM_10,
  RTEMS_RECORD_EVENT_SYSTEM_11,
  RTEMS_RECORD_EVENT_SYSTEM_12,
  RTEMS_RECORD_EVENT_SYSTEM_13,
  RTEMS_RECORD_EVENT_SYSTEM_14,
  RTEMS_RECORD_EVENT_SYSTEM_15,
  /* User event domains */
  RTEMS_RECORD_EVENT_USER_0,
  RTEMS_RECORD_EVENT_USER_1,
  RTEMS_RECORD_EVENT_USER_2,
  RTEMS_RECORD_EVENT_USER_3,
  RTEMS_RECORD_EVENT_USER_4,
  RTEMS_RECORD_EVENT_USER_5,
  RTEMS_RECORD_EVENT_USER_6,
  RTEMS_RECORD_EVENT_USER_7,
  RTEMS_RECORD_EVENT_USER_8,
  RTEMS_RECORD_EVENT_USER_9,
  RTEMS_RECORD_EVENT_USER_10,
  RTEMS_RECORD_EVENT_USER_11,
  RTEMS_RECORD_EVENT_USER_12,
  RTEMS_RECORD_EVENT_USER_13,
  RTEMS_RECORD_EVENT_USER_14,
  RTEMS_RECORD_EVENT_USER_15,
  RTEMS_RECORD_EVENT_USER_16,
  RTEMS_RECORD_EVENT_USER_17,
  RTEMS_RECORD_EVENT_USER_18,
  RTEMS_RECORD_EVENT_USER_19,
  RTEMS_RECORD_EVENT_USER_20,
  RTEMS_RECORD_EVENT_USER_21,
  RTEMS_RECORD_EVENT_USER_22,
  RTEMS_RECORD_EVENT_USER_23,
  RTEMS_RECORD_EVENT_USER_24,
  RTEMS_RECORD_EVENT_USER_25,
  RTEMS_RECORD_EVENT_USER_26,
  RTEMS_RECORD_EVENT_USER_27,
  RTEMS_RECORD_EVENT_USER_28,
  RTEMS_RECORD_EVENT_USER_29,
  RTEMS_RECORD_EVENT_USER_30,
  RTEMS_RECORD_EVENT_USER_31,
  RTEMS_RECORD_EVENT_USER_32,
  RTEMS_RECORD_EVENT_USER_33,
  RTEMS_RECORD_EVENT_USER_34,
  RTEMS_RECORD_EVENT_USER_35,
  RTEMS_RECORD_EVENT_USER_36,
  RTEMS_RECORD_EVENT_USER_37,
  RTEMS_RECORD_EVENT_USER_38,
  RTEMS_RECORD_EVENT_USER_39,
  RTEMS_RECORD_EVENT_USER_40,
  RTEMS_RECORD_EVENT_USER_41,
  RTEMS_RECORD_EVENT_USER_42,
  RTEMS_RECORD_EVENT_USER_43,
  RTEMS_RECORD_EVENT_USER_44,
  RTEMS_RECORD_EVENT_USER_45,
  RTEMS_RECORD_EVENT_USER_46,
  RTEMS_RECORD_EVENT_USER_47,
  RTEMS_RECORD_EVENT_LAST = 0xffffffff
} rtems_record_event;
void rtems_record_produce( rtems_record_event event, rtems_record_data data );
00000000 <rtems_record_produce>:
   0:   7c a0 00 a6     mfmsr   r5
   4:   7c 00 01 46     wrteei  0
   8:   7d 6e 82 a6     mfspr   r11,526
   c:   7d 30 42 a6     mfsprg  r9,0
  10:   81 09 02 b0     lwz     r8,688(r9)
  14:   80 e8 00 00     lwz     r7,0(r8)
  18:   81 28 00 04     lwz     r9,4(r8)
  1c:   80 c8 00 08     lwz     r6,8(r8)
  20:   39 29 ff ff     addi    r9,r9,-1
  24:   7d 27 48 50     subf    r9,r7,r9
  28:   7d 29 30 38     and     r9,r9,r6
  2c:   2b 89 00 01     cmplwi  cr7,r9,1
This is the only branch in the function:
  30:   41 dd 00 40     bgt-    cr7,70 <rtems_record_produce+0x70>
  34:   54 ea 08 3c     rlwinm  r10,r7,1,0,30
  38:   38 60 00 00     li      r3,0
  3c:   7d 4a 3a 14     add     r10,r10,r7
  40:   7d 27 4a 14     add     r9,r7,r9
  44:   55 4a 10 3a     rlwinm  r10,r10,2,0,29
  48:   7d 29 30 38     and     r9,r9,r6
  4c:   7d 48 52 14     add     r10,r8,r10
  50:   90 6a 00 0c     stw     r3,12(r10)
  54:   91 6a 00 10     stw     r11,16(r10)
  58:   90 8a 00 14     stw     r4,20(r10)
  5c:   7c 20 04 ac     lwsync
  60:   91 28 00 00     stw     r9,0(r8)
  64:   7c a0 01 06     wrtee   r5
  68:   4e 80 00 20     blr
Only 27 instructions in the common path (no ring buffer overflow, overflows are special events).
  6c:   60 00 00 00     nop
  70:   54 ea 08 3c     rlwinm  r10,r7,1,0,30
  74:   39 20 00 01     li      r9,1
  78:   7d 4a 3a 14     add     r10,r10,r7
  7c:   7d 27 4a 14     add     r9,r7,r9
  80:   55 4a 10 3a     rlwinm  r10,r10,2,0,29
  84:   7d 29 30 38     and     r9,r9,r6
  88:   7d 48 52 14     add     r10,r8,r10
  8c:   90 6a 00 0c     stw     r3,12(r10)
  90:   91 6a 00 10     stw     r11,16(r10)
  94:   90 8a 00 14     stw     r4,20(r10)
  98:   7c 20 04 ac     lwsync
  9c:   91 28 00 00     stw     r9,0(r8)
  a0:   7c a0 01 06     wrtee   r5
  a4:   4e 80 00 20     blr
