RTEMS5 _REENT
Wed Nov 7 07:38:31 UTC 2018
On 07/11/2018 08:23, Ian Caddy wrote:
>>> Or should this be fixed to check whether multi-tasking is running
>>> before checking the currently running thread, we do this in some of
>>> our other code?
>> Code which runs before the idle threads are created should not use
>> complex Newlib functions. Unfortunately snprintf() is a complex
>> Newlib function. I think we need a low level replacement for
>> snprintf() which could be used during BSP initialization for example.
>> This could be a simple wrapper for _IO_Printf().
>> I had a similar issue here:
>> https://lists.rtems.org/pipermail/devel/2018-September/023013.html
> Thanks, I must have skipped over that one from a short time ago.
> The problem is that we end up doing quite a lot of complicated things
> before multi-tasking is started, and there is not going to be a simple
> way around that for us with quite a large code base.
> I am still wondering whether or not I can change the __getreent
> function to detect whether multi-tasking has started yet or not and
> either return the task executing element or return the _GLOBAL_REENT
> for the time before.
> I am wondering what other side effects there will be and whether this
> is better than defining CONFIGURE_DISABLE_NEWLIB_REENTRANCY. I might
> try an experiment to check which method might be better for us.
If you update to the current master
https://git.rtems.org/rtems/commit/?id=d1f7204649ff7c8bed36eab5af20c1a108af8b14
then you could try to add this to the module which contains your
application configuration:
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
struct _reent *__getreent(void)
   Thread_Control *executing;
   executing = _Thread_Get_executing();
   if (executing != NULL) {
     return executing->libc_reent;
   } else {
     return _GLOBAL_REENT;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
